ady8077
| posted on 29/1/06 at 07:17 PM |
diamond cut wheel edges
Hi all
Is it possible to diy a polished edge?
Adrian
k33ts
| posted on 29/1/06 at 11:28 PM |
depends what sort of condition there in
if there already diamond turned wouldnt be to hard
remove the laquer with paint stripper comes off suprisingly easy if you follow the instructions.
if you want to get rid of diamond turn rub down with 1200 wet and dry then get hold of a polishing wheel on a drill or angle grinder with some polish
paste and youll get get a fairly good job
if there painted in the first place i wouldnt bother trying as itll take absolutely ages
better off taking them to a profesional polisher if you want them spot on dont charge as much as you think if you prep them in the first place
ady8077
| posted on 30/1/06 at 06:17 PM |
Hi
they are curently painted, but i want to paint them black and thought a polished rim would look good
