New Topic New Reply
Author: Subject: mk R1 gear linkage
kev R1
posted on 9/2/06 at 09:11 PM Reply With Quote
mk R1 gear linkage
any one got any pics of there r1 engined indy gear linkage? think my brake adjust valve might be in the way?
zxrlocost
posted on 9/2/06 at 09:21 PM Reply With Quote
why not go paddle
kev R1
posted on 9/2/06 at 09:30 PM Reply With Quote
Really can't be bothered to be quite honest with you, just want to get it ready asap!
OX
posted on 9/2/06 at 09:38 PM Reply With Quote
well going the paddle way is just as easy as the normal way.
where is your brake adjustment valve
kev R1
posted on 9/2/06 at 09:39 PM Reply With Quote
attatched to the driver side footwell,near your clutch foot(other side obviously) how much did your paddle cost to do ox?
richijenkin
posted on 9/2/06 at 09:42 PM Reply With Quote
make me an offer if want dude:
http://www.locostbuilders.co.uk/viewthread.php?tid=38659
kev R1
posted on 9/2/06 at 09:46 PM Reply With Quote
have you got a pic? is it just the lever or the whole mech'?
richijenkin
posted on 9/2/06 at 09:51 PM Reply With Quote
Just the lever, but the mechanics to it is just as easy as a normal stick.
no pic yet
[Edited on 9/2/06 by richijenkin]
kev R1
posted on 9/2/06 at 09:52 PM Reply With Quote
have you got a pic? how much do you want? u2u me
donut
posted on 10/2/06 at 07:39 AM Reply With Quote
Check out desyboys pic archive for linkage ideas.
click here.......>
[Edited on 10/2/06 by donut]
Jasalarms
posted on 10/2/06 at 03:54 PM Reply With Quote
Go on Kev go with the paddle!
Think i have the shifter cable i was goner use still, if i can find it.
But as ox says, the brake switch will be in the way for a normal mech shifter.
Would be more positive using a push rod setup for a paddle shift, the cable way has been done before, but might be a bit sloppy in operation.
As Delboy always said......" You know it makes sense"
posted on 10/2/06 at 06:23 PM Reply With Quote
One thing to bear in mind though, is that if you decide to go the paddleshift route, you'll have to do away with the stalks on the Sierra column which will mean finding an alternative way to operate indicators and lights
Not too difficult to do, just means more switches on the dash. Indicator issue might also be a PITA.
kev R1
posted on 10/2/06 at 07:30 PM Reply With Quote
stalks have already gone and got a switch already wired in for the indicators so not a prob, any one know what stops the paddle shift bit floating around?
zxrlocost
posted on 10/2/06 at 08:38 PM Reply With Quote
yep the rest of the mechanism and rose joints
it all comes together when you see it and as you do it
desyboy
posted on 10/2/06 at 10:32 PM Reply With Quote
paddles
why do the sierra stalks have to be removed?
INDY BIRD
posted on 14/2/06 at 07:47 PM Reply With Quote
Doing a paddle shift myself
? where is the best place to get the rose joints from any ideas??
Sean
New Topic New Reply
