Wadders
posted on 16/2/06 at 02:54 PM |
Workshop floor paint
Anyone know whats the most durable paint finish for a concrete garage floor, and where to buy.
cheers
Al
flak monkey
posted on 16/2/06 at 02:57 PM |
Leyland Industrial floor paint.
Good stuff, but it isnt cheap
http://www.leyland-paints.co.uk/site/ourProducts.asp?range=6
Sera
http://www.motosera.com
andyb64
posted on 16/2/06 at 02:59 PM |
Johnstone Trade paints on Meanwood
Road have heavy duty floor paint suitable for concrete floor and it was on special offer when I was in there recently. I think they do it in several
colours
Andy...
Having seen the previous post, thats the stuff I saw in Johnstones
[Edited on 16/2/06 by andyb64]
Wadders
posted on 16/2/06 at 03:11 PM |
Thanks for the swift response guys, i'll pop down tommorow and see if they have any.
andylancaster3000
posted on 16/2/06 at 04:17 PM |
We used the stuff Screwfix sell. Although cheap, it seems to have given a suprisingly tough finish.
James
posted on 16/2/06 at 04:26 PM |
I've bought the Screwfix but never used it. What did any of you use to clean the floor first? If anything?
I'm just wondering if the dust from the concrete floor itself will prevent the paint from still well.
James
- Muhammad Ali
posted on 16/2/06 at 05:01 PM |
Use a weak pva mix to seal the floor and let it dry well before painting.
Danozeman
posted on 16/2/06 at 07:10 PM |
THin some of the paint down and give it a first coat with that.
Alot of motor factors do floor paint. The Dx work stuff isnt bad although it need a couple of coats.
Dan
MkIndy7
posted on 16/2/06 at 07:16 PM |
The proper Industrial paint has an Etching Acid that you use first, if you have it done on the cheep without the acid first it just peels off wherever
cars/vans/forklifts etc run.
Wadders
posted on 16/2/06 at 08:13 PM |
who sells that stuff? any idea what its called
chris.russell
posted on 16/2/06 at 08:18 PM |
etch
Mines a pint
greglogan
posted on 16/2/06 at 10:07 PM |
I have you used Grey Oxide paint to great success. It's used for painting steel normally but I have used it very successfully. It's also
very cheap to buy.
[Edited on 16/2/06 by greglogan]
Women are meant to be loved, not understood.
miserableoldgit
posted on 16/2/06 at 11:52 PM |
Floor Paint
I've used the Leyland floor paint with good results, despite there being several areas of oil or other contaminent spillage. No sign of pealing
but some chipping where I've dropped something heavy and hard.
Perfection you ain't gonna get unless you use one of the very expensive resin based products.
Go cheap and repaint as required. Either that or use the Gulval system and carpet it!
Youth and vitality are wasted on the young
40inches
posted on 17/2/06 at 09:06 AM |
I used Wickes grey floor paint, they use it in all the stores, so at least you can see it before you buy and it gets some hammer! Use patio acid
cleaner to etch the concrete (also from Wickes).
