Author: Subject: Talking of garage floors and oil leaks...
posted on 17/2/06 at 02:34 PM Reply With Quote
Any bright ideas for mopping up spilt oil from a concrete garage floor?
I don't care about the stain, I just don't want to walk it around the house afterwards.
I used to sprinkle cement over oil, but then I walked oily cement dust through the house...
SWMBO tended to get upset...
Johnmor
posted on 17/2/06 at 02:37 PM Reply With Quote
Sawdust
Sawdust, better than cement and is clean to use. Not sure how easy it for you to get hold of but its the best by far..
posted on 17/2/06 at 02:38 PM Reply With Quote
prevention is better.
if your coucil is into recycling then the l;ids for the recycleing boxes are good - large area and shallow or buy some washing basins from poundland. Lots and lots of newspapers help too!!
On those rare moment, I would wipe up oil using newspapers and rags, a bit of sand on top then paraffin to scrub the floor.
Or just buy more cars to park over the stains to hide them
andyace
posted on 17/2/06 at 02:40 PM Reply With Quote
Petshops
nitram38
posted on 17/2/06 at 02:42 PM Reply With Quote
Cat litter/fullers earth (fresh of course!)
posted on 17/2/06 at 02:45 PM Reply With Quote
'Prevention' is a nice concept - it doesn't help when you wander into the garage and see a puddle of oil under the car...
(see thread in 'engines' - now resolved)
I like the cat litter or sawdust options...
Avoneer
posted on 17/2/06 at 02:50 PM Reply With Quote
Cat litter is good as well.
Sawdust is best though.
When you're at the petshop buying some, but a couple of 99p cat litter trays.
Great for changing the oil and collecting drips etc.
Pat...
graememk
posted on 17/2/06 at 02:52 PM Reply With Quote
i use cat litter works very well
balidey
posted on 17/2/06 at 03:44 PM Reply With Quote
Use 'fresh' cat litter.
stevebubs
posted on 17/2/06 at 04:06 PM Reply With Quote
For prevention, dough trays from your local Domino's Pizza work quite well...pretty shallow but with plent of volume - just park your car over it....
posted on 17/2/06 at 04:20 PM Reply With Quote
I do normally have a tray under the engine... but this time it was the steering rack that leaked, with the oil trickling along the bodywork and dripping out by the nosecone.
And, for info, it's accidental leaks I'm trying to clean up, not the common x-flow ones!
[Edited on 17/2/06 by David Jenkins]
marshall
posted on 17/2/06 at 04:30 PM Reply With Quote
if i was you i would use fine sand.
Johnmor
posted on 17/2/06 at 05:51 PM Reply With Quote
Sand?
Beware the sand, done that, even after a good sweep everything i dropped was coated in abrasive annoying crap.
DIY Si
posted on 17/2/06 at 06:24 PM Reply With Quote
Tesco/Sainsbury's/where ever's bugdet cat litter. Once dropped a complete sump on the floor Took an afternoon, but the floor ended up cleaner than it had been in the morning! And it cost a few quid.
BKLOCO
posted on 17/2/06 at 06:59 PM Reply With Quote
Linky Linky Might help. Not locost I know
posted on 17/2/06 at 07:21 PM Reply With Quote
David, try your local motor factors for oil absorbant granules. Spread over oil leak , put on an old pair of boots and scuff it in . As used in most garages , they should know about oil leaks.
