Author: Subject: piston ring compressor - stepped cylinder
posted on 23/3/06 at 10:47 AM Reply With Quote
I'm sure I saw a piston ring compressor but can't rememebr where. What was special about it was that instead of being a spring steel cylinder, it was step shaped cylinder (like you would get if you took a square profile roofing sheet and made a tube from it ; this had advantage that there is less friction on the ring plus you can poke a screwdriver or other implement in the raised steps to help prod the ring into place.
Anyone make sense of this and if I did not imagine this, where can I buy one?
bilbo
posted on 23/3/06 at 11:37 AM Reply With Quote
Look up part number JSL21700 at www.burtonpower.com
Is this what you're looking for?
Bill
posted on 23/3/06 at 11:58 AM Reply With Quote
This the fella?
Part No: JSL21700
Status: Available from stock.
Item Price: £13.53
Surcharge: £0.00
Price: £15.90 (inc.Vat)
Description: WRINKLE BAND RING COMPRESSOR
Other Info: RANGE: 76.2mm - 127mm Rescued attachment JSL21700.jpg
posted on 23/3/06 at 12:10 PM Reply With Quote
got the catalogue so probably where I saw it
has anyone used one of these and found it is better than the band type (not exactly as locost as a big jubille clip )
posted on 23/3/06 at 12:16 PM Reply With Quote
NS Dev
posted on 23/3/06 at 03:52 PM Reply With Quote
I have a long serving piece of tin and jubilee clip, always worked ok so far, splash of EP90 helps things along.
Cousin Cleotis
posted on 23/3/06 at 05:57 PM Reply With Quote
i have the crinkle band type, the tool had lots of burrs and sharp edges to score pistons. it works very well one the edges have been dressed.
Paul
posted on 23/3/06 at 08:25 PM Reply With Quote
I always used a bean can cut down the side and a jubilee clip but a few years ago I invested in a proper one, only about £5. I used lots of engine oil with STP round the inside while I knocked the piston down with the hammer shaft and never had any problems.
