Author: Subject: alloy rods - anyone tried them yet?
posted on 28/3/06 at 01:38 PM Reply With Quote
new product at Frosts:
http://www.frost.co.uk/item_Detail.asp?productID=9220
If I understand correctly, they are like lumiweld/technoweld but easier to use.
wondering if anyone has tried them?
DaveFJ
posted on 28/3/06 at 02:21 PM Reply With Quote
I'm interested as well, I have been considering trying this when I get around to doing the cut&shut on my efi plenum.......
Dave
JAG
posted on 28/3/06 at 02:43 PM Reply With Quote
I've used the Technoweld product and it works very well.
Main problem is getting enough heat into the workpiece. Bigger parts are very difficult to get hot enough for long enough. Aluminium conducts heat very well and the joint area cools too quickly to melt the rods.
I think you'll have difficulty with the EFI plenum - it's way bigger than anything I've ever done. I would suggest finding a local TIG wleder who'll help you out.
Justin
DaveFJ
posted on 28/3/06 at 03:09 PM Reply With Quote
that's kinda what I suspected.....
Dave
MikeR
posted on 28/3/06 at 04:20 PM Reply With Quote
Interested in the manifold approach - any pics + more detail on the construction would be appreciated.
posted on 28/3/06 at 07:35 PM Reply With Quote
We used lumiweld to fit some lugs to a bike frame and they were still on two years later when the bike was sold. Welduk sells some stuff here that's supposed to be even easier to use.
johnjulie
posted on 29/3/06 at 10:43 PM Reply With Quote
have a look at
www.repairaluminium.com
cheers John
JFDI
"Just F*****G Do It"
JAG
posted on 3/4/06 at 08:38 AM Reply With Quote
Nice work Mark.
I'm pleased to hear it's possible to do bigger stuff and impressed with the quality of your work.
What sort of temperature did you set the oven at?
The Technoweld rods should melt around 300 Celsius (I think) so I guess you were set at the upper end of a domestic oven range - say 220-240'ish
Did you take any precautions to stop the manifold cooling once you had removed it from the oven?
Justin
MikeR
posted on 3/4/06 at 04:56 PM Reply With Quote
hmmm, 300 degrees ...... mine has a special mode that will take it up to something like 350 for cleaning. If i could just override the locking mechanism this could get interesting!
posted on 3/4/06 at 05:06 PM Reply With Quote
I bought a bernzomatic blowlamp off ebay the other week and on mapp gas it will melt aluminium, so it should be up to alu brazing. The HST2000 or whatever rods are used at 270* according to some reading I found on them.
