Ferrino
posted on 3/4/06 at 05:40 PM |
Oval Grommet
Does anyone know where I can find a range of small oval blanking grommets (or something similar to blank an oval/rectangular hole, but which is
removeable & looks neat)?
Basically, I have a removeable gearstick (I will use an electronic gearshift, with the mechnical shift there as a backup, but I don't want it
there during normal use) and want to blank the hole on the tunnel that the stick goes through.
Thanks!
omega 24 v6
posted on 3/4/06 at 09:06 PM |
Get a normal grommet which will, when fitted, form the shape required. And then superglue a peice of inner tube across the hole thats left. Superglue
is great on rubber parts mate.
posted on 4/4/06 at 08:15 AM |
you can buy them from specialist tool shops that sell oval drills.
posted on 4/4/06 at 08:46 AM |
I've seen a demo of a drill that makes square holes... seriously!
It takes a bit of extra kit in the drill press to make it work.
JonBowden
posted on 4/4/06 at 10:24 AM |
Just a thought, sea kayaks have big grommets covering storage holes - probably too big, but perhaps
Jon
