iscmatt
posted on 3/4/06 at 08:01 PM |
Anti roll bar
The bolts on my sierras anti roll bar are stuck fast - i've tried soaking the bolts in good old WD40 but to know avail. Is there any way i can
get it off or do i resort to the trusty angle grinder?
posted on 3/4/06 at 08:05 PM |
you mean the 15mm ones into the chassis or the ones holding it to the lower arms? Longer bar, or impact wrench
iscmatt
posted on 3/4/06 at 08:10 PM |
Yup its the 15mm nuts thanks for you help i'll look into it
MikeR
posted on 3/4/06 at 08:23 PM |
try getting some plus gas. Its a lot more effective than WD40.
iscmatt
posted on 3/4/06 at 08:33 PM |
what is plus gas/where can i get it from? will it be usful throughout my build?
Patching Cars
posted on 3/4/06 at 08:40 PM |
Blowtorch, or hot wrench as it's often called. Heat them up till they're nice and hot the put the breakers bar on them, never fails.
Rob
iscmatt
posted on 3/4/06 at 08:46 PM |
ah i see! well i've got a blow torch - somewhere! Thanks, will work on it tommorrow morning!
posted on 3/4/06 at 09:23 PM |
You shouldn't need to undo them --- to get the struts off.
DaveFJ
posted on 4/4/06 at 07:56 AM |
blob of weld on the head of the bolt... warms it up nicely
Dave
iscmatt
posted on 4/4/06 at 09:28 AM |
i'm taking out the gearbox seperatly so it needs to go
quote: Originally posted by DaveFJ
blob of weld on the head of the bolt... warms it up nicely.
No welder as yet but i'll try the blow tourch today and let you know how it goes. cheers
iscmatt
posted on 4/4/06 at 07:54 PM |
no luck with the blowtourch or a longer handled ratchet, hacksawed off the bolts - took a while but its sorted and can get on.
