Author: Subject: ally grinding
theconrodkid
posted on 4/4/06 at 06:08 PM Reply With Quote
ally grinding
ive cut the inlet manifold for my zetec up so all i have is the mounting plate and some stubs.
what is the best way of making the stubs flat and all level,grinding discs clog very quickly
who cares who wins
pass the pork pies
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 4/4/06 at 06:13 PM Reply With Quote
Removing Alloy
One way of making the grinding discs last longer is by cleaning them by grinding some steel every so often in between your bits of alloy grinding.
Alternatively use a coarse (bastard cut) file. When filing alloy you can drag the file back over the work as this helps clear the file. When filing steel you should lift the file off for the back stroke otherwise you burr over the teeth.
John
daviep
posted on 4/4/06 at 06:17 PM Reply With Quote
Be careful grinding ally with steel grinding discs. They choke up then when you grind steel the ally packed in to the wheel heats up and expands and the wheel shatters.
theconrodkid
posted on 4/4/06 at 06:23 PM Reply With Quote
cheers for yr replies,btw i,m using soft discs not the biscuit ones.
jb are you who i think you are,if so ive oggled your moggy many times
who cares who wins
pass the pork pies
Triton
posted on 4/4/06 at 06:41 PM Reply With Quote
Mr conrod,
Now this will sound totally bonkers but I can assure you it works just dandy......spin the clean disc up then run a bar of normal hand soap accross it....works on files as well.
You have to keep doing it every now and then but it stops the discs clogging up.
Mark
[Edited on 4/4/06 by Triton]
www.tritonraceseats.com
www.hairyhedgehog.com
theconrodkid
posted on 4/4/06 at 06:52 PM Reply With Quote
soap?whats that?i wash in petrol once a month
cheers,ill give it a try
who cares who wins
pass the pork pies
owelly
posted on 4/4/06 at 07:08 PM Reply With Quote
or load the file with french chalk.
http://www.ppcmag.co.uk
posted on 4/4/06 at 07:34 PM Reply With Quote
French???? That won't work either!!! Show em a bit of hard work and they roll out the white flag!!!!
DIY Si
posted on 4/4/06 at 07:37 PM Reply With Quote
But it could mean you produce some fine wine and cheese. Make the afternoons out better. Although it would take the work shy buggers a while.
BKLOCO
posted on 4/4/06 at 07:49 PM Reply With Quote
Use a flap wheel in the angry grinder. Available from screw fix.
Triton
posted on 4/4/06 at 08:02 PM Reply With Quote
soap works on flap wheels as well as grinding and cutting discs, hacksaw blades, files....even been known to help clean your hands 'n face.
Trev D
posted on 4/4/06 at 08:07 PM Reply With Quote
Soap is what we use in the trade on all ally grinding and cutting regards Trev.
theconrodkid
posted on 5/4/06 at 07:09 AM Reply With Quote
cheers peeps
who cares who wins
pass the pork pies
posted on 5/4/06 at 09:46 AM Reply With Quote
Carbolic?
Get some of that carbolic soap and you won't need to grind it, it'll dissolve the aluminium from 10 paces.
posted on 7/4/06 at 08:22 AM Reply With Quote
'Best' way would be to take it to local engineering company and get them to stick it on a milling machine. Should be a very quick/cheap operation.
theconrodkid
posted on 7/4/06 at 08:32 AM Reply With Quote
i managed to find some 36 grit discs,they knocked it down real quick,just need a 1/2 round file to clean up holes in plenum now,why dont "new" files work when "old" (ones that saw service in ww2)ones do
who cares who wins
pass the pork pies
