mickeyLocost
posted on 8/4/06 at 08:39 AM |
Screwfix Wolf products
Any opinions on these 2. Was considering buying both for myself, im not a pro so dont want to pay top dollar but still need something thats useable
for most things. Has anyone any experience of them?
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=72403
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=73259
cheers
PROGRESS SO FAR: Bought the book!
posted on 8/4/06 at 08:54 AM |
http://www.transtools.co.uk/150022comp45ltr.htm
this is a better compressor on paper, 3hp rather than 2 and £30 less.
The welder is gasless, ive never used one but they have a poor reputation. For a little more you could get a 'proper' one.
mickeyLocost
posted on 8/4/06 at 10:25 AM |
thanks thats really good. I want a gasless welder because I will be welding outdoors and I've read that once you get the settings right they can
be good.
Mike R-F
posted on 8/4/06 at 10:37 AM |
I got the older version of the Wolf compressor some time ago and although it's OK in most respects & gives a reasonable spray finish if
you're painting, it's not up to blowing primer/filler nor is it powerful enough for most air tools. I'm actually thinking of getting
another one & running the two of them together. I mention this only as I see the Transtools one is out of stock. I really should have bought a
bigger one at the start.
mickeyLocost
posted on 8/4/06 at 11:40 AM |
I think im gonna wait for the transtool one to come back in to stock. Want to start with the biggest I can afford. Gonna ring them monday and see how
long it will be.
posted on 8/4/06 at 11:53 AM |
if anyone is considering the two compressor approach, it works well. With both mine running (only 3.5hp total iirc) i can get near continous use of
the die grinder and cut off tool. The latest is an aldi special.
Dusty
posted on 8/4/06 at 04:01 PM |
I think its a false economy to buy a gasless mig. You should get a gas/gasless which will do both and if you don't buy a 150amp mig you will
regret it later. Just my opinion.
Danozeman
posted on 8/4/06 at 04:26 PM |
Id stay away from gasless myself. Gas is a far better weld.
Dan
Marlon
posted on 8/4/06 at 05:23 PM |
I have that Wolf compressor and although it has done what I needed it to, I wish that I had bought a bigger one in the beggining. As a welder by trade
imho I would avoid the gassless and go for the gas as i find it far better to work with!
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
