Author: Subject: Removing stubborn bolts etc.
BKLOCO
posted on 11/4/06 at 10:23 AM Reply With Quote
Here's a tip for all those who are in the stripdown stage of either their engine or donor .
We all know about the sharp whack on the bolt head with a hammer to shock the threads and loosen stubborn bolts but here's a tip for preventing "cam out" of screw drivers, Allen keys, Torx bits etc. It even works with spanners to stop them rounding off nuts!!!
Most of us that have been playing with engines for a while will have hidden on the top shelf, tucked away at the back somewhere a tin of valve grinding paste.
Dip the tip of the tool in the course end before using it, or smear the spanner jaws.
Trust me you will be amazed at how much extra "purchase you can get on the tool before it slips.
There is a product sold by RS called screw grab that does the same job at twice the price!!!
The only down side is that if you are using this method on engine internals you must ensure that you remove all traces before re assembly.
smart51
posted on 11/4/06 at 10:27 AM Reply With Quote
top tip mate
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 11/4/06 at 10:40 AM Reply With Quote
Keep the tips coming!
stevec
posted on 11/4/06 at 04:39 PM Reply With Quote
Heres one,
When you are drilling holes in your chassis and other metal bits put a magnet close to where you are drilling and it will catch most of the horrible swarf that gets everywhere.
I use one out of an old wiper motor.
BKLOCO
posted on 11/4/06 at 04:45 PM Reply With Quote
Originally posted by stevec
Heres one,
A great tip.
A circular one out of an old loudspeaker is even better as you drill in the centre of the magnet.
We use them all the time at work on printing presses where you don't want swarf falling on the plates.
flak monkey
posted on 11/4/06 at 04:47 PM Reply With Quote
Nice tip
Heres another one:
If you are trying to drill a hole in thin sheet, they usually come out triangular due to the way the drill cuts.
Before drilling the hole place a bit of emery cloth on the sheet and drill through that. The hole will then be round. Works every time
Sera
http://www.motosera.com
trextr7monkey
posted on 11/4/06 at 05:45 PM Reply With Quote
When crossing a one way street only look one way and save time for more important things inlife!!
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 11/4/06 at 06:06 PM Reply With Quote
Catching Swarf
A vacuum cleaner also does a good job of collecting swarf when drilling / cutting / maching etc.
John
Russ-Turner
posted on 11/4/06 at 06:33 PM Reply With Quote
Housewives: I find the best way to get two bottles of washing-up liquid for the price of one is by putting one in your shopping trolley and the other in your coat pocket.
Taxi drivers: Why not pop into the garage and ask them to fix your indicators lights for you so that other motorists know where the f*** you're going.
Olympic athletes: Disguise the fact that you've taken anabolic steroids by running a bit slower.
Courtesy a'la VIZ.
locoboy
posted on 14/4/06 at 08:59 PM Reply With Quote
Nice tip
Heres another one:
How come?????????
Im intrigued now!
Locoboy
