Locost82
posted on 20/4/06 at 12:57 PM |
Tube Cutting Saw
I've got a Chop Saw which I have been using to cut wood. Is it possible to convert this with a new blade to cut steel tube for the chassis? My
arm is getting very tired now and I'm looking at the saw with growing desperation.
iank
posted on 20/4/06 at 01:07 PM |
No, a plain wood chop saw has the wrong speed for steel.
Ian Pearson
posted on 20/4/06 at 01:42 PM |
It may not be recommended practice, but I put a steel cutting disc in my wooden chop saw, and have used it for cutting all my steel. Have had no
problems at all, but would obviously not recommend this potentially harmful practice to anyone!
trikerneil
posted on 20/4/06 at 06:48 PM |
Nor would I
ACE Cafe - Just say No.
posted on 20/4/06 at 06:59 PM |
if its powerful enough it will be fine. The proper ones are about 2kw. Ive cut sheet on my table saw without even changing the blade, though
admittedly i did loose a few teeth!
caber
posted on 20/4/06 at 07:28 PM |
Joel
was that when the saw threw the sheet in your face:-)
Caber
posted on 20/4/06 at 07:44 PM |
on later attempts i decided to wear safety glasses, but you just have to hold it firmly! This was admittedly thinish stainless, from an extractor
chimney.
Locost82
posted on 21/4/06 at 07:45 AM |
Cheers guys.
I guess I'll struggle on with the trusty old hacksaw, there's no point building a Locost I can't drive because I've disabled
myself
My angle-grinder is surprisingly good at cutting out the damaged tubes, but not accurate enough to cut the replacements.
