Author: Subject: Welding mild to stainless?
RazMan
posted on 23/4/06 at 05:24 PM Reply With Quote
I need to MIG weld some 3mm stainless to some 4mm mild steel - nothing structural but it needs to be a reasonably good weld.
Which wire should I use - mild or stainless?
Raz
nitram38
posted on 23/4/06 at 05:42 PM Reply With Quote
Mild steel will work, but do not expect the weld to be strong. Another option is silver solder. It all depends on the abuse it will get.
Or, get someone to tig it for you using a 'dissimilar' rod.
Jon Ison
posted on 23/4/06 at 05:45 PM Reply With Quote
As long as its not structural normal mig wire and loads a power will give a nice weld.
nige
posted on 23/4/06 at 06:17 PM Reply With Quote
mild to stainless
we discussed this last week and
our coded welder @ work says to use
stainless but for best results you need
disimaler , i think this applies to stick
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
trikerneil
posted on 23/4/06 at 07:15 PM Reply With Quote
I welded a steel exhaust to a stainless silencer adapter using ordinary steel MIG wire, worked OK for me
ACE Cafe - Just say No.
owelly
posted on 23/4/06 at 08:53 PM Reply With Quote
I made a pair of stainless inner wings for my Discovery and welded one side with SS and the other with MS (I ran out of SS!). There was no noticable difference. I s'pose the chromy stuff all gets mixed up anyway!!
http://www.ppcmag.co.uk
posted on 23/4/06 at 09:09 PM Reply With Quote
just remember the vapours
posted on 23/4/06 at 10:58 PM Reply With Quote
I think I'm turning Japanese? They were definitely one hit wonders Are they welders now?
