tks
posted on 26/5/06 at 09:10 AM |
Water cutting service?? Waterjet cutting service?
Does anyone knows a good service where i could place an order for some ally plates i need??
think it will be a 80pounds order ore close to it.
(for those remember its for my transmission)
any one??
Tks
Slater
posted on 26/5/06 at 09:51 AM |
Try these guys, based up near Aberdeen.
http://www.poseidonengineering.com/index.htm
the linky thing worked, wow!.
Keith.
[Edited on 26/5/06 by Slater]
Simon
posted on 26/5/06 at 07:15 PM |
Just had my turbo in/ex flanges cut by
http://www.sciss.co.uk/
from 10mm stainless steel. Used a bit of thin card pressed against holes, and this is the result:
We use them a lot for work too!!
Simon
posted on 28/5/06 at 02:22 AM |
Simon, could you give a rough price for a one off job such as a manifold flange?
Simon
posted on 28/5/06 at 10:52 PM |
Mike,
When my father gets the bill (I included it in quite a bit of stuff he was having cut!), I'll check to see if they split it out. If so,
I'll let you know.
HTH
Simon
NS Dev
posted on 31/5/06 at 03:11 PM |
for stainless etc surely lasering is much cheaper than waterjet, or have prices changed a lot in the last couple of years?
posted on 1/6/06 at 11:01 PM |
Thought lasering stainless was difficult as it is too shiny?
NS Dev
posted on 2/6/06 at 11:58 AM |
see where you're coming from Mike but there were piles and piles of lasered bright stainless at NSI when I was there yesterday!
Bit I liked best were the deep drawn stainless vessels that they were laser cutting ports into the walls of on their 5 axis laser, beauty of a
machine!
