Author: Subject: should i be using PTFE tape?
shades
posted on 31/5/06 at 08:04 PM Reply With Quote
prob a stupid question... should I be using ptfe tape on fuel, oil and water lines?
bit unsure about fuel lines especially, using copper pipe with compression fittings (supplied by tiger), and more so with fuel injection...
anything i should be doing/considering?
stevec
posted on 31/5/06 at 08:08 PM Reply With Quote
As a general rule compression fittings dont need tape and taper type fittings may do.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 31/5/06 at 09:03 PM Reply With Quote
Sealing
generally there are 2 types of hose fitting or pipe fitting.
The ones that seal on a taper or compression of the pipe do not require any tape or sealant for the threads.
The other is a tapered pipe fitting that seals on the threads. In this case use tape or liquid sealant.
John
posted on 31/5/06 at 09:06 PM Reply With Quote
In my days manufacturing compression fittings for domestic water. Tighten olive nut hand tight then spanner turn through 90 more degrees. It doesn't feel like it's sealed but it should be.
However, in practice I always use BOS White to make sure (kind of runny window putty, if you're old enough to remember!)
We haven't used sealant on any compression fittings (brake or fuel)anywhere on our build and basically have stuck to this principle without a sinlge leak.
[Edited on 31-5-06 by Hellfire]
posted on 31/5/06 at 09:21 PM Reply With Quote
main cause of leaks on compression fittings is overtightening causing them to deform. At least if you turn it 90 degrees and it leaks, you can safely nip it up a little more!
stevec
posted on 31/5/06 at 10:48 PM Reply With Quote
Hellfire.
Thats what I said.Not on compression fittings. Or have I misunderstood your note?
[Edited on 31/5/06 by stevec]
MkIndy7
posted on 1/6/06 at 12:21 AM Reply With Quote
You need paste or PTFE on cheap plumbing compression fittings these days!
Particularly "Eagle" brand fittings that look like there made from sweetie wrapers!
[Edited on 1/6/06 by MkIndy7]
stevebubs
posted on 1/6/06 at 01:12 AM Reply With Quote
so what is the consensus on PTFE and fuel / brake fluid?
trikerneil
posted on 1/6/06 at 04:26 AM Reply With Quote
I've used Loctite 572 thread sealant on my brakes with no problem.
Loctite 243 lock n seal is supposed to be oil and petrol resistant.
ACE Cafe - Just say No.
posted on 1/6/06 at 09:51 AM Reply With Quote
Brakes don't seal on the threads, they seal on the flare and should not need anything on the threads.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
posted on 1/6/06 at 06:29 PM Reply With Quote
Brake Fittings
The only thing I would recommend on Cupro-Nickel brake line compression fittings is some copper grease on the inside of the fitting where the brake pipe goes through it.
This means the day you come to undo it the nut will turn and not twist the brake pipe, meaning you do not have to make a new hard line.
John
