Author: Subject: gilbow 10"
liam.mccaffrey
posted on 1/8/06 at 11:44 AM Reply With Quote
gilbow 10"
how thick will gilbow 10" tinsnips cut in mild steel sheet?
Many Thanks
Build Blog
Build Photo Album
RazMan
posted on 1/8/06 at 11:58 AM Reply With Quote
About 1.2mm iirc
Raz
posted on 1/8/06 at 12:07 PM Reply With Quote
I've cut 16g with mine but it's hard work if you're not just trimming the edge off something, they will cut 20g like paper. The problem is getting the waste side of the cut out of the way. I use a drill powered nibbler I bought at a show for £30, it cuts 16g easily as long as you oil the cut line.
