NigeEss
posted on 4/8/06 at 02:47 PM |
Torque Question for Boffins
Anyone have a calculation I could use to calculate torque applied using a
lever of length x and load of y grammes ?
It's for a physics lesson thing.
iank
posted on 4/8/06 at 02:52 PM |
More than you could ever need
http://en.wikipedia.org/wiki/Torque
matt_claydon
posted on 4/8/06 at 02:55 PM |
Yeah, torque in Newton-Metres is Load in Newtons x Length in metres (surprisingly )
1 Newton is 102 grammes so:
Torque = Mass(g) x Length(m) / 102
Hope this helps...
Matt.
[Edited on 4/8/06 by matt_claydon]
gingerprince
posted on 4/8/06 at 02:56 PM |
http://www.comfsm.fm/~dleeling//physics/torque.html
Torque is force x distance x sin(angle)
SO at 90 degrees the torque eg of 1 kilo at 1metre from fulcrum is 1 x 1 x sin(90) = 1NM. Torque decreases with sin as angle changes.
matt_claydon
posted on 4/8/06 at 03:00 PM |
That would actually be 1kgm = 9.81Nm.
Good point about the angle though.
Matt.
gingerprince
posted on 4/8/06 at 04:07 PM |
Depends what planet you're on. I was working on the assumption of a planet slightly larger than earth where 1Kg exherts 1N
You were indeed correct to point out my c0ck up tho!
[Edited on 4/8/06 by gingerprince]
smart51
posted on 4/8/06 at 04:14 PM |
Gravity varies with altitude and latitude. Find yourself a nice below-sea-level valley away from the equator and your 1kg = 1N fantasy might come
true!
trikerneil
posted on 4/8/06 at 05:57 PM |
Also depends on underlying rock.
ACE Cafe - Just say No.
tks
posted on 4/8/06 at 07:42 PM |
anyway its the reason
i wanted a transmission box because my prop had quet some angle
20 / 30 degrees.
Tks
