RazMan
| posted on 1/9/06 at 03:33 PM |
Can I get a bush for this?
I've got some alloy hinges which need to be threaded to take an M6 bolt. They are countersunk at the moment so I would have to tig the holes and
redrill & tap but I am a little concerned that they might be weakened as a result.
It then occurred to me that a steel hank bush or something similar could be pressed into the countersunk side, allowing a stronger M6 thread.
Does anyone know of something suitable?
Raz
DarrenW
| posted on 1/9/06 at 04:10 PM |
What size are the holes and countersinking to start off with. Could you not use M6 cap heads and use the existing countersinking? I probs dont
understand the application enough to advise. Dont recall fitting doors to mine
MkIndy7
Could you not drill and tap them M8?
stevebubs
| posted on 1/9/06 at 04:25 PM |
rivnut??
BKLOCO
| posted on 1/9/06 at 04:36 PM |
Mike you only have to ask...
I'm not a million miles away you know.
Get some measurements and I'll turn you up some stainless threaded inserts.
Ill come round at the w-end if you like and we can have a measure up.
RazMan
| posted on 1/9/06 at 05:06 PM |
Brian - you are a STAR
Just to cover the points mentioned...
The bolts need to come in from the back of the hinge ie the opposite side to the c/sink.
Drilling out to M8 will probably take all the meat out of the hole and make it too fragile.
I did think of a rivnut but the hole would be too large (same reasons as above)
Thanks for the input guys - looks like its BKLOCO to the rescue again!
Raz
| posted on 1/9/06 at 08:06 PM |
Have you thought about using a spoke nipple? If you can get them in 6mm they would probably be suitable
RazMan
| posted on 1/9/06 at 10:36 PM |
I like your lateral thinking Rusty but I can only find small (around 2mm) spoke nipples. Nice idea though
Raz
