Author: Subject: Engine Analyzer (How???)
oliwb
posted on 26/9/06 at 04:19 PM Reply With Quote
On a whim I bought myself a cheap and cheerful engine analyzer from Maplins. It was cheap because they'd lost the box etc so I've got no instructions. Its the:
Mastech MS 6231
Doesn't seem very complicated does rpm, dwell, temp and usual multimetre tricks.....but I've got no idea how to use all the feature as its got no instructions! I looked on the Mastech website and it lists it and tells you the features but no manuals!
Has anyone got this one or does anyone know how to use them in general?? Cheers Oli.
caber
posted on 26/9/06 at 06:15 PM Reply With Quote
Oli, The temp should be a thermocouple of some sort, did you get one with the kit? Dwell and RPM are measured between the coil connection from the points and ground, RPM says the same as your rev counter and dwell will be meaningless with your megajolt, it gives you the points duration timing for conventional points if you have any vehicles with such things!
Caber
oliwb
posted on 26/9/06 at 07:17 PM Reply With Quote
Cheers, didn't get a thermocouple and there doesn't appear to be any plug for it either....I'll bring it down south next week and you can have a play see if you can work it out! Cheers Oli.
