Author: Subject: Compression Test on BEC?
Guinness
posted on 29/9/06 at 06:33 PM Reply With Quote
In the middle of rebuilding my engines at the moment and was going to compression test them, but I can't see how!
My plugs are about 4" down from the cam cover and the spark plug spanner is about 6" long.
Linky to Screwfix Tester
How do you screw that in tight? Does it come apart?
Confused
Mike
smart51
posted on 29/9/06 at 06:42 PM Reply With Quote
just screw the tube in finger tight. It should be enough to nip up the rubber O ring.
Be careful if you have a screw on extension piece to reduce the thread diameter. when I did mine, only the tube came out. I had to put a drop of super glue on the larger thread and screw it back in quickly to get the reducer out.
Wadders
posted on 29/9/06 at 06:43 PM Reply With Quote
My old fashioned comp tester, long deceased
didn't screw into the spark plug hole, it just had a big rubber cone shaped end, which you pressed hard into the hole while cranking the motor. maybe you could knock up something similar to adapt yours? that way you could just shove it into the hole in the cam cover.
stevec
posted on 29/9/06 at 06:44 PM Reply With Quote
It dosnt need to be that tight, it only seals on the "O" ring, so you should be able to feed it down the plug hole, twiddle it around and rotate the rubber pipe until it is nipped up.
Steve.
oops a bit slow there!
[Edited on 29/9/06 by stevec]
Guinness
posted on 29/9/06 at 06:47 PM Reply With Quote
Cheers me dears!
Mike
