tks
posted on 8/10/06 at 06:27 PM |
Some TIPS and Tricks!
Last couple of weeks done allot of small important things on the car discovered some thing wich i never heard or saw over here.. sow here it goes!
1) If you have rear discs and need to bleed them, use the upphole of the hub, turnarround the caliper and bolt it with one bolt to the hub! Now your
bleed screw is facingupwards and you can easyly bleed the system while the caliper is bolted!
2) Front wings: i had the luego wing stands but it can be done with everyone!
For realy nice fitment, cut the strip (bended metal) just that it doesn't brake, you will get a U shape! now you can easyly bend it upwards and
generate the perfil needed for perfect front wing mounting. You will need to do it again to bend the strip parrallel to the wheel again! tackwelld,
reweld it and paint it and your stays are rigid and perfectly fitted.
this way you can easyly archive the full wing dept as offset to the wheel surface!
Regards,
Tks
