posted on 10/10/06 at 02:12 PM |
bending an 8 mm aluminium tube
I want to bend into a 120 mm circle a piece of split 8 mm diameter aluminium tubing.
The idea is to make a wooden disc, 120 mm diam. and two strips of steel running from a central pivot. Allowing for tihickness of the tube, a
bolt/roller or pad arrangement is fitted to the strips that will press on the tube when it is laid along the edge fo the wooden disc.
As the strips (levers) are moved, the tube is brought toward the disc bending it in the process hopefully without kinking it. (to stop the slit from
clsoing up, a strip of ali is put into the tube).
So rather like the windscreem frame making jig in the book.
Is this likley to work - anyone done smilair?
posted on 10/10/06 at 02:26 PM |
quote: Originally posted by 02GF74(to stop the slit from clsoing up, a strip of ali is put into the tube).
I think that will cause grief, you will be trying to bend a strip if ally in it's stiffest plane, very likely it will just kink and warp.
Probably better if you make you wooden wheel from two halves with a slightly larger aluminium wheel of the correct thickness in the middle. This will
guide the tube and prevent the slit closing.
posted on 10/10/06 at 02:31 PM |
ah yes, but where exaclty is the slit?
ok, I sould have explained better.
draw three 3 concentric cicles. the largest and smallers are the tube, the line in the middle is the slit. the strip to hold the slit open will bent
easist along that pane.
RichardK
posted on 10/10/06 at 07:26 PM |
Can't ya fill it with sand and then plug the ends? Then bend it
Rich
[Edited on 10/10/06 by RichardK]
zetec7
posted on 10/10/06 at 08:15 PM |
If possible, bend it BEFORE you split it!!
