Author: Subject: Step Drill Speed
caber
posted on 10/11/06 at 09:38 PM Reply With Quote
Step Drill Speed
I just bought one of these and was wondering what the best speed was to get a good finish on steel sheet, do you run these fast or slow?
Mark Allanson
posted on 10/11/06 at 09:48 PM Reply With Quote
Really slow, cutting oil in moderation or it will burn
caber
posted on 11/11/06 at 12:14 AM Reply With Quote
Mark,
Caber
zetec7
posted on 11/11/06 at 01:32 AM Reply With Quote
Glad you asked that - not because I knew the answer, but because I needed to know as well. I bought a set of those things, and haven't tried 'em out yet. Probably would have fried one before finding out myself...
http://www.freewebs.com/zetec7/
posted on 15/11/06 at 09:34 AM Reply With Quote
if you bought one from screwfix, throw it in the bin now; you'd be lucky to do two 20 mm holes in 2 mm steel.
No need to ask how I found that out - in the end bought one made in UK, Sheffield(yes, some things are still made in UK) for > £ 20 and has done 10 times the holes and still going string.
(i.e. if you have paid less than £ 20, expect SF kwalitee).
NS Dev
posted on 15/11/06 at 12:49 PM Reply With Quote
yep, as usual you get what you pay for, and a bit of support for things made properly in this country never goes amiss!!
owelly
posted on 15/11/06 at 08:37 PM Reply With Quote
If my memory serves me correct, the cutting speed for mild steel is around 24m/minute.
So a 10mm hole would want a speed of 776rpm.
13mm hole would like 597rpm.
I would use the slower of the calculated figures if you are using a cone cutter. If the largest size you are making is 13mm, then use the 13mm cutting speed. I hope this makes sense?
http://www.ppcmag.co.uk
caber
posted on 16/11/06 at 08:27 AM Reply With Quote
Thanks for the responses, Owelly that is very useful! I managed to get the holes cut cleanly with a power drill on lowest speed!
Caber
posted on 16/11/06 at 12:34 PM Reply With Quote
Caber
I've had to make big holes in 2-3 mm steel and did it using a cordless drill, slow speed.
That was too fast so I pulsed the trigger, ptress on/off so the average speed is much sloer - did the job.
