Author: Subject: Flickering lights
dnmalc
posted on 31/12/06 at 08:26 PM Reply With Quote
Flickering lights
Help any suggestionsto over come the following;
When I am welding SWMBO complains that the lights etc in the house flicker even when I am using it on the minimum setting as it is only a 150 amp Snap On I don't think it should be drawing any significant spikes.
nib1980
posted on 31/12/06 at 08:31 PM Reply With Quote
turn the lights off
theconrodkid
posted on 31/12/06 at 08:32 PM Reply With Quote
buy her some candles and tell her they are romantic
who cares who wins
pass the pork pies
dnmalc
Unfortunately her fix is to switch the welder off
macnab
posted on 31/12/06 at 08:33 PM Reply With Quote
normal
All my neighbours moan when I'm welding, 'it's like a disco in here, bla bla'
To simulate this effect try turning the kettle on & off really quickly...
907
posted on 31/12/06 at 08:35 PM Reply With Quote
It's Christmas. Shouldn't be a problem this time of year.
Paul G
flak monkey
posted on 31/12/06 at 08:43 PM Reply With Quote
Its also really good for your computer if its turned on at the time...
Sera
http://www.motosera.com
stevec
posted on 31/12/06 at 08:57 PM Reply With Quote
Give her money to buy shoes, usually fixes it.
macspeedy
posted on 31/12/06 at 08:58 PM Reply With Quote
I though it was the wind, could blame it on that!
Edinburgh hogmany cancelled
goodall
posted on 31/12/06 at 09:49 PM Reply With Quote
get your self a seperate electriy surply coming from a nearby 10kv pole this way it won't affect anyone, would require a bit of money tho
goodall
posted on 31/12/06 at 09:50 PM Reply With Quote
or just put your foot down
RazMan
posted on 1/1/07 at 01:32 AM Reply With Quote
My SIP 150 causes the same flickering even though the garage is on a separate feed. I just try and do any welding during daylight hours
Raz
dnmalc
posted on 1/1/07 at 05:55 PM Reply With Quote
I had womdered if a screening transformer would be beneficial but then the welder has a fairly substantial transformer in it anyway
posted on 1/1/07 at 09:07 PM Reply With Quote
its an annoying problem that one. My table saw causes the lights to flicker and its only 2kw! Basically a voltage drop as the motor/transformer coils fill up.
907
posted on 1/1/07 at 09:41 PM Reply With Quote
You think you've got probs
You ought to see my spot welder... 6000 amps for 0.2sec
That makes street lights dim; or it would if we had any.
Paul G
goodall
posted on 2/1/07 at 12:10 AM Reply With Quote
but you have to remember your paying for it and its not your problem its the electrity surpply companies
