NS Dev
| posted on 17/1/07 at 07:56 PM |
32mm (1.25" ) pipe bending die needed
anybody got a 1.25" or 32mm OD pipe bending die for a hydraulic pipe bender (32mm OD not nominal bore) that I can borrow for a while?
Its not a size that's used much on car stuff but I need it for the lighter non safety critical bitrs of my grasser spaceframe, will be too heavy
if I plan in much more 45mm!!!
liam.mccaffrey
| posted on 17/1/07 at 07:57 PM |
probably, but theres no way i could get it out of the tool store in work, sorry
[Edited on 17/1/07 by liam.mccaffrey]
Build Blog
Build Photo Album
3GEComponents
| posted on 17/1/07 at 09:59 PM |
Nat, do you mean one of these? If so they're for 33mm OD, i think i've got one, i'll check and get back to you.
MikeR
| posted on 17/1/07 at 11:40 PM |
if a pipe one will work, David Irvine has some - and with him being in holland i'm sure a long term loan can be organised.
gazza285
| posted on 18/1/07 at 06:20 AM |
You can probably get away with one inch nominal bore formers, which are 33.4mm, get MikeR to nick Mr Irvines.
If not I might have one, but for a manual bender, not a hydraulic one. I'll look and see if I have any 312 MMA rods as well.
Had a look, I've got LOHIs and 316L rods but no 312.
[Edited on 18/1/07 by gazza285]
NS Dev
| posted on 18/1/07 at 08:17 AM |
Cheers Gazza, have got some 312mma rods sorted from work now, and just bought a handful of 312 tig rods from a chap on ebay (as they were £80 a pack
didn't fancy getting a full tubeful!!)
Mike - can you speak to Dave and see if that is ok, that die will do the trick, would be great if he can spare it for a while!!!
cheers folks
Nat
