kj
| posted on 30/1/07 at 06:16 PM |
welding?
has any body used this, could it used be on petrol tank's or pannels ? from screw fix, check the web site or the book on page 135, liquid metal.
stevec
| posted on 30/1/07 at 06:28 PM |
do you mean this
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=23269&ts=81624
No but I bet RH will use it on their next car to attach the wishbone mounts.....
Hehehehe
Metal / metal epoxy bonds are often quite strong. I'd imagine a 2-pack bond will often be stronger than something in a caulking tube. After all,
if it glues to blooming everything why doesn't it glue to the inside of the tube- at least with 2 pack epoxy it would once you've mixed
'em....
Oh perhaps I'm being simple
kj
| posted on 30/1/07 at 06:32 PM |
nope thats not the stuff. its in a tube
| posted on 30/1/07 at 06:41 PM |
Linky
that's the stuff....
diyer
| posted on 30/1/07 at 06:50 PM |
Hehehehe
Yawn yawn yawn
Hug a Hoodie!
MikeR
| posted on 30/1/07 at 07:03 PM |
part of me says, that it can only glue to metal ...... hence is ok in a plastic tube.
but i don't believe that!
| posted on 30/1/07 at 08:10 PM |
I got some of that stuff or similar, evostick, says as strong as weldiing, my ar5e
admitedly I stuck on a piece of meatl onto fibre glass and was able to pull it off, and I am not supehumanly strong.
I doubt very much that is will fare better with metal; maybe I should go and plonk it on tow boits of steel and see (it's vold now but if there
are enough request, I';ll do it )
| posted on 30/1/07 at 08:21 PM |
Still a sore subject then......
I'll go and hide in the corner until the all clear sounds
Hehehehe
Yawn yawn yawn
Simon
| posted on 30/1/07 at 08:25 PM |
Heard a story of a chap who wanted to deseam his mini, so used chemical metal over the (ground down) seams, sanded and sprayed. He was apparently
quite impressed with it, till he drove orf
Simon
[Edited on 30/1/07 by Simon]
mark chandler
| posted on 30/1/07 at 09:20 PM |
Heard a storey about a chap who built a roll cage using chemical metal.... the scrutineer gave it three blows from a sledge hammer and it was in
bits.
For a gradually increasing load it may be strong but cannot take shocks and the shear value is very limited so to be avoided. weld it !
| posted on 31/1/07 at 12:22 AM |
I wouldn't trust it on a tank but it might work o.k. as a panel adhesive.
kj
| posted on 31/1/07 at 06:46 AM |
i would rather weld, just thought i would get people's opinion.
