zetec7
| posted on 12/2/07 at 09:20 AM |
De-scratching Plexi and Lexan
I had a bit of a shunt in July on my Kawasaki Concours (hit a large deer ), and gouged up the edge of my new (and expensive!) Lexan windscreen. I
was going to go to a local plastics shop, but on the pohne they didn't sound too hopeful about being able to fix it, so in a fit of pique, I
thought I'd have a go myself. I started off sanding down past the gouges with 80 grit black oxide paper, then to 200 grit. Then I used 400
grit, 600 grit (wet) and 1000 grit (wet). By then it was nice and smooth, but opaque. I used some strange "Made in France" polish (it
may be familiar to you in the UK, but here no-one's ever heard of it) called "Ouater". It's kind of a cotton wool soaked in
day-glo pink goo, which is a very fine abrasive. Anyway, after 10 minutes soft polishing with that, it was perfectly clear! No scratches, just like
new!!! - Posted in case others find the information useful...
http://www.freewebs.com/zetec7/
RazMan
| posted on 12/2/07 at 09:27 AM |
Ouater, pronounced "water" is a metal polish designed for aluminum. It is very aggressive when in contact with paintwork - it will stripo
the paint right off so be careful with it.
Nice to know it works on plastic
Raz
| posted on 12/2/07 at 09:35 AM |
quote: Originally posted by zetec7
It's kind of a cotton wool soaked in day-glo pink goo, which is a very fine abrasive.
jewellers rouge perhaps?
| posted on 12/2/07 at 10:53 AM |
You can also use toothpaste. Used to get scratches out of crystal juggling balls don't you know
And your windscreen with be plaque free and minty fresh for weeks!!!
liam.mccaffrey
| posted on 12/2/07 at 11:02 AM |
id heard someone say toothpaste is good for scratched cds
Build Blog
Build Photo Album
PeterW
| posted on 12/2/07 at 11:17 AM |
Anyone know a supplier of this Ouater stuff in the UK...?
Peter
Phil.J
| posted on 12/2/07 at 01:53 PM |
I used some stuff made by Meguires (called Plastex I think) to polish the windows in the soft top of my Moke, worked really well on this sort of soft
plastic.
Phil
