scottc
| posted on 17/2/07 at 02:22 PM |
110v light -> 240v ??
I have a 110v twin halogen spotlights on a stand, but have no 110v electricity!
Can I....change the bulbs and the plug and use 240V? I assume the current will be half of what it is with 110v so the wiring should be fine.
If it makes any difference the bulbs are 500w.
owelly
| posted on 17/2/07 at 02:26 PM |
Just swap the bulbs and the plug and the jobs a carrot.....
http://www.ppcmag.co.uk
PaulBuz
| posted on 17/2/07 at 02:58 PM |
just wire 'em in series!!
...only joking, just change the lamps.
Paul
scottc
| posted on 17/2/07 at 03:01 PM |
funnily enough Paul I had thought about that.
scottc
| posted on 17/2/07 at 04:28 PM |
Cheers guys works a treat
| posted on 17/2/07 at 07:02 PM |
in theory that should work, in practise the bulbs will not have identical resistance so one bulb may draw more current that it can handle and go
pop - this is the principle of Christmas tree lamps.
Since the bulbs are of no use unless you invest in a 240/110 transformer you might as well put tiem in series, if it blowes, then you need 240 V
bulbs.
make sure that the housingm, contacts etc: can e made safe to be wired in series
caber
| posted on 17/2/07 at 09:17 PM |
In practice it works just fine wiring lamps in series. When I used to do Rock and Roll lighting all the rigs were 120V lamps paired in series in a
great big patch panel on the dimmer racks!
Caber
