| posted on 9/3/07 at 04:44 PM |
Alternatives to engine painting
Any other options?
My aged alloy engine (now 17 years old) is rather scanky and I fancy giving it a little refurb. Personally not a fan of painted engines... Nothing
too silly (not mirror finish) just get rid of some of the crud.
Steam cleaning is quite good from what I've heard but how much crud will it actually remove? And down sides???
TIA
| posted on 9/3/07 at 05:16 PM |
paint it silver to match original or just some clear varnish.
nitram38
| posted on 9/3/07 at 05:17 PM |
Have it bead blasted?
RazMan
| posted on 9/3/07 at 05:56 PM |
I bought a hand held steam cleaner from B&Q and went over the alloy engine & box with that - it looked really clean and shiny .... for a
while. Now it looks like a scanky donor engine again If I get the chance again I will paint them with engine enamel.
Raz
Confused but excited.
| posted on 9/3/07 at 06:08 PM |
Leave it until winter, then take it out and polish it. Should be finished for spring!
tegwin
| posted on 9/3/07 at 06:51 PM |
Can you get it steam cleaned and then anodised in a colour of your choice?
dnmalc
| posted on 9/3/07 at 07:28 PM |
Alochrome
ayoungman
| posted on 9/3/07 at 09:37 PM |
clean it, then wire wheel on an angle grinder followed by silver engine paint. Nothing too fancy, but it will stay presentable for years to come.
"just like that !"
designer
| posted on 10/3/07 at 08:20 AM |
If magnesium is very clean it can be sprayed with WD40 to keep it looking good. I presume aluminium could be the same.
| posted on 10/3/07 at 11:14 AM |
Hmmmmm. Sounds like whatever I do the engines going to go back to how it is pretty quickly... might not bother
| posted on 10/3/07 at 01:05 PM |
might not bother
That's certainly an alternative
stevebubs
| posted on 10/3/07 at 07:01 PM |
quote: Originally posted by BenB
Any other options?
TIA
Paint it unless you want to be cleaning it after every run....although if you've a reasonably sealed engine bay that will prevent grime getting
in then you may get away with every other run....
