cadebytiger
| posted on 8/4/07 at 09:43 AM |
Drift?
This is i know a stupid question but i just wanted to check and thats what you lot are great for!!
I am adjusting the front shocks and have been told to knock the lower spring holder around with a drift untill i have about 4.5 - 5inches ground
clearance.
What should the drift be made from? I am assuming it should be something soft to stop any damage being down.
Thanks for the help
Rupert
Kev99
| posted on 8/4/07 at 09:55 AM |
I wouldn't use a drift might damage the adjuster
Jack the car up and use one of those oil filter removal tools put some cloth between it an the adjuster nut and u don't damage it
somthing like this
http://cgi.ebay.co.uk/OIL-FILTER-WRENCH-OIL-FILTER-STRAP-REMOVAL-TOOL_W0QQitemZ120105107748QQcategoryZ30917QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
cadebytiger
| posted on 8/4/07 at 09:57 AM |
ahhh i have one of those!!
not sure it will go in there tho. it's inboard!
| posted on 8/4/07 at 10:00 AM |
cant you use a c spanner on the adjuster? Does it not have slots in it?
RazMan
| posted on 8/4/07 at 10:09 AM |
Surely a C spanner will do the trick?
Raz
cadebytiger
| posted on 8/4/07 at 10:13 AM |
they are spax shocks so you would have thought so yes. not sure why tiger (Jim himself) did not suggest this?!
Rupert
cadebytiger
| posted on 8/4/07 at 10:14 AM |
where is it best to get one of these from?
UncleFista
| posted on 8/4/07 at 10:20 AM |
On my Nitrons, a couple of drill bits in the adjuster holes and a twist allows adjustment
Tony Bond / UncleFista
| posted on 8/4/07 at 10:30 AM |
A drift works just fine just use a nice soft bit of aluminium alloy or brass or copper bar stock.
mark chandler
| posted on 8/4/07 at 12:09 PM |
Make sure you loosen the grub screw first !
| posted on 8/4/07 at 12:43 PM |
Stilsons work
They go big enough to grip the nut.
NS Dev
| posted on 10/4/07 at 12:30 PM |
reason tiger said drift it was that they prob assumed if you were asking then you didn't have a c spanner!
Schrodinger
| posted on 10/4/07 at 01:13 PM |
If you are in Peterboro then Tiger as its just down the road.
I assume it's a Cat you have, contact
http://www.chestersportscars.co.uk/
IIRC they suggest a different approach to gaining more ride hight as winding up the spring seats does have a negative effect in making the ride very
hard and twitchy. I think you will find it quite hard to get the level of clearance you are after by just winding up the platforms.
[Edited on 10/4/07 by Schrodinger]
