the_fbi
posted on 8/4/07 at 05:26 PM |
Making car ramps?
My current ramps are under the Westfield and also had a tendancy to "skid" when trying to drive a car up them.
So I'm thinking about making a pair with a smaller slope which will reducing the skidding problem.
Any ideas as to a safe design?
The ones pictured below are about right, although I'd make the slope a bit longer which will help with low cars too. Clearly all the verticals
are equal angle which gives good strength, in actual fact its all equal angle.
Any thoughts as to the best thickness to use or improvements to that design appreciated.
ta
Chris
RazMan
posted on 8/4/07 at 05:31 PM |
How about making some mini sized ramps to lead up to the bigger ones? That way you could remove the small ones, leaving the car on the bigger ones and
have more room to move around the car.
Just a thought
Raz
Stand them on some rubber backed carpet and they won't skid out. If you just put two cross pieces spaced out on the top your wheel will drop in
when you get there.
omega 24 v6
posted on 8/4/07 at 05:41 PM |
Get some old seat belts/tie down straps and loop round the bottom rung then lay them along the floor where the wheels will be running and drive up.
the_fbi
posted on 8/4/07 at 06:03 PM |
Thats a good tip!
So, 2 pieces, a ramp and a stand.
The middle of the top 5 pieces missing so the tyre drops in and locates nicely.
Straps on the front to self anchor to the tyre.
ta
Neville Jones
I welded some checker plate to the bottom of the ramps on mine, so the car goes on the plate before it goes up the ramp.
This stops the car pushing the ramps away, and actualy has the car pulling itself into and up the ramp, sted of pushing it away.
Nev.
Mr Whippy
posted on 8/4/07 at 09:01 PM |
Nev.
oh very clever, I like that
tks
posted on 8/4/07 at 09:09 PM |
yeah with other words...
add 1 (2) foot of angle and 2 scross sections..
Tks
p.d. mayme it also makes sense to join the 2 stands together by some way...
[Edited on 8/4/07 by tks]
Johnmor
posted on 8/4/07 at 09:22 PM |
I glued 1" stip of rubber along the bottom of the ramps, never move now.
wilkingj
posted on 8/4/07 at 09:39 PM |
STOP poncing about.....
Build some Real Ramps
LINKY
You know it makes sense... Dont do half a job, when you could make it fully baked!
Best Regards
Geoff
http://www.v8viento.co.uk
the_fbi
posted on 8/4/07 at 10:05 PM |
LINKY
Unfortunately one of my tintops weighs 1385KG, that would need some serious strengthening to take it.
Neat solution for a lightweight car though.
