chockymonster
posted on 12/4/07 at 09:59 PM |
M8 Die
It's a bit of a cheeky long shot.
Does anyone have a decent M8 die I can borrow?
I have to cut 2 threads into a piece of A2 stainless rod and my die just isn't up to the task.
I know they're not massively expensive it's just I'm only going to cut 2 threads and then cast it into the box of other tools
I've bought to do just one job!
welderman
posted on 12/4/07 at 10:15 PM |
die or die nut
Thank's, Joe
I don't stalk people
emsfactory
posted on 12/4/07 at 11:08 PM |
quote: Originally posted by welderman
die or die nut
whats the difference?
chockymonster
posted on 12/4/07 at 11:20 PM |
Die nut.
Reading on tapdie.co.uk it would seem that their die nuts aren't suitable for cutting a new thread. Does that go for all die nuts?
chockymonster
posted on 12/4/07 at 11:24 PM |
die or die nut
Die is round, a die nut is shaped like a nut
posted on 13/4/07 at 05:53 AM |
A die is for cutting new threads, a die nut is for sorting out existing mangled threads... usually. A die nut can make new threads, but (a)
they're not intended for that job, and (b) you'll have a difficult job starting the thread straight.
ned
posted on 13/4/07 at 06:10 AM |
Where in hampshire are you? I have a set off HSS tap/dies from which you could borrow what you need if not too far away?
Ned.
beware, I've got yellow skin
worX
posted on 13/4/07 at 08:00 AM |
He's in Andover, so prob about 40mins from you in traffic!!!
chockymonster
posted on 13/4/07 at 09:41 AM |
You can tell he's never been to guildford!
Cheers for the offer Ned, I think with petrol costs etc I may as well buy another only use once tool
ned
posted on 13/4/07 at 12:17 PM |
You're welcome!
Basingstoke is about 30 mins and stonehenge an hour - on a good run so worX isn't too far out
Ned.
ps since buying my set I've used them a lot more than once! This is what I bought, great value for money if you're happy to pay the
initial outlay. Will come in handy a lot more often than you think!
http://www.lawson-his.co.uk/scripts/products.php?cat=Tap%20and%20Die%20Sets#LINEAR%20TOOLS21-599-SET
[Edited on 13/4/07 by ned]
