Author: Subject: Arc, Mig or Gas less Mig, That is the question
darrens
posted on 21/4/07 at 11:15 AM Reply With Quote
As above which one, ruled out arc to a degree but can't decide on Mig or Gasless Mig. It's not going to be used allot just the odd thing.
Anyone any recommedations
posted on 21/4/07 at 11:19 AM Reply With Quote
If you are welding outside in windy conditions gasless has adavantages BUT it the welds are less clean than with argon/co2 mix, it also produces a fair ammount of spatter ( but it is less adherent than spatter from a co2 mig).
Also the area around the weld gets coated in flux deposits which need wire brushed off.
ghuncha
posted on 21/4/07 at 11:57 AM Reply With Quote
well was about to post the same question....
well i cant get my hand on any type of mig over here, so can a arch do the job of chassis fabrication...
blakep82
posted on 21/4/07 at 12:00 PM Reply With Quote
mig.
that is all
i've had gasless, the welds are alright for tacking things together, but i wouldn't do any structural welding with it. the welds are pretty messy too. wire is very expensive (£36 per kg from halfords, compared to about £2 per kg for normal wire)
mig, yes you need to think about the gas, but it's fairly cheap
[Edited on 21/4/07 by blakep82]
________________________
turbodisplay
posted on 21/4/07 at 12:12 PM Reply With Quote
MIG, but buy a good one. Bought a cheap one (£150). Thought my welding was poor, got a clarke 175te MIG a few days ago. Perfect welds!
The cheaper ones have very poor motors that judder under load, so the weld is porous and messy.
Darrren
Fatgadget
posted on 21/4/07 at 12:21 PM Reply With Quote
You need years and years of experience to arc weld properly.
zetec7
posted on 21/4/07 at 02:24 PM Reply With Quote
Mig with gas. You'll never look back...
http://www.freewebs.com/zetec7/
dave r
posted on 21/4/07 at 03:59 PM Reply With Quote
i have stick, mig and tig
mostly use the tig
ecosse
posted on 21/4/07 at 04:01 PM Reply With Quote
Gasless is fine if you buy the right stuff, and it can work out cheaper depending on how much welding you do (machine mart 5kg = £43) but as said the welds are messier (spatter) and it takes more practice to get a good weld, but its no less effective than using co2 IMO.
If going with gas though don't use the disposable bottles, costs a bloody fortune!
Alex
robertst
posted on 21/4/07 at 05:10 PM Reply With Quote
i'm doing fine with my arc welder.... i would have loved to use a MIG though...
i went for arc as (in the true locost spirit) it was the cheapest option, and MIG ones here cost a fortune.
arc's fine, but i do reccommend a MIG, if you see what i mean
Tom
darrens
posted on 22/4/07 at 07:24 PM Reply With Quote
cheers for all replies, looks like mig is in favour
dsapsfo1
posted on 24/4/07 at 08:54 AM Reply With Quote
Many of the MIGs will now run with or without gas, depending on the wire you use and changing the polarity on the machine - you can then choose which is most appropriate, depending on conditions etc.
NS Dev
posted on 25/4/07 at 12:01 PM Reply With Quote
Darrren
GOOD ADVICE!!!!
save your money up and buy a good one.......
a cheap mig will really pee you off, trust me!
