StevieB
| posted on 16/5/07 at 06:09 PM |
Round tube bolt on attachments thingies
I'm after some sort of clamp type thing to attach around my steering column so I can attach my bike switches behind the steering wheel - does
anyone know:
a. What I mean
b. What they're called
c. Where I can get some from
MkIndy7
| posted on 16/5/07 at 06:12 PM |
Would an Exhaust Clamp be any good?
You could attatch something to the front face of the flat bit that usually hangs down underneath.
StevieB
| posted on 16/5/07 at 06:44 PM |
Maybe.
I have a friend who said he'd weld a piece of nike handlebar straight onto the column, but I think the metal may be a little thin for that and
get a hole blown in it all too easily.
stuart_g
| posted on 16/5/07 at 06:50 PM |
I'm sure someone has done this quite recently, have you tried a search?
StevieB
| posted on 16/5/07 at 06:54 PM |
I'm searching now, but it's a hard topic to pinpoint!
| posted on 16/5/07 at 07:09 PM |
Something like a solid anti roll bar clamp in 2 halves around the column?
stuart_g
found it for you
O.K. so it was a bit a while back, doesn't time fly when you're having so much fun.
http://www.locostbuilders.co.uk/viewthread.php?tid=41734
StevieB
| posted on 16/5/07 at 07:22 PM |
Cheers for that - I knew I'd seen it somewhere before but could find it in the search function!
I guess a steel tub to fit over the sierra column top with a grub screw should do the trick!
Alan B
| posted on 17/5/07 at 01:34 AM |
Google for shaft collars...robust and plenty of choice.
StevieB
| posted on 17/5/07 at 06:37 PM |
Thanks - shaft collars are exactly the thing I was looking for (just didn't have a clue what they were called).
£7 from RS Components!
Alan B
| posted on 17/5/07 at 07:29 PM |
Glad I could help....they are very versatile pieces of kit....I use a lot in my designs (at work), often drilling and tapping them or welding lugs on
etc.
StevieB
| posted on 17/5/07 at 08:46 PM |
My company use RS Components all the time - I love all the little bits and bobs that we get around the office, but never actually get to use anything
because I'm a bean counter, so as much as I like to see all the techy bits at heart, I have to shout at people for buying too may!
But, I'm thinking the next order may accidentally come with a few sizes of shaft collar and I won't get overly upset...
Alan B
| posted on 17/5/07 at 08:50 PM |
