scottc
| posted on 16/5/07 at 10:38 PM |
Timing light recommendation
I'm after a timing light with an advance function. Long story short my project car has only a single mark, being TDC. Ignition timing should be
10 degrees BTDC.
I could mark the crank pulley. But it's only about 5" in diameter, and with the margin of error I'm likely to introduce will end up
being somewhere between 5 and 15 BTDC.
or does anyone in Newcastle have one I can borrow?
oh might need a gas tester for a few days too
| posted on 17/5/07 at 08:02 AM |
I reckon one should be able to make one using white LEDs for a couple of quid. LED technology has advance a lot recently so shoiuyld be bright
enough.
flak monkey
| posted on 17/5/07 at 08:09 AM |
Just buy a strobe, the middle of the range gunson one has an advance function on. Think they are about £40 in halfrauds, prob cheaper on ebay.
Its not that difficult to mark the pulley, but you will have to take it off to do it accurately.
Sera
http://www.motosera.com
scottc
| posted on 17/5/07 at 09:04 PM |
Thanks Flak,
Did just that. with the advance function I don't need to mark the pulley :-)
Cheers guys.
DarrenW
| posted on 18/5/07 at 08:37 AM |
I managed to get a digi snap on strobe light off ebay. Fantastic bit of kit. Great investment for £30.
