Author: Subject: Maybe I should reinforce my shelving...
posted on 1/7/07 at 06:54 PM Reply With Quote
Perhaps I trusted Machine Mart's finest shelving a bit too much...
[Edited on 1/7/07 by David Jenkins] Rescued attachment bent-shelf.JPG
Simon
posted on 1/7/07 at 06:57 PM Reply With Quote
Simon
Wadders
posted on 1/7/07 at 07:02 PM Reply With Quote
Did you not see that one coming David
Must be catching, one of the draw runners on my 'Professional Heavy Duty' machine mart toolbox has collapsed today only had spanners in, so hardly being abused, Pile of poo, better start saving for a snap on
Al.
scottc
posted on 1/7/07 at 07:11 PM Reply With Quote
Notice its sagging right underneath the middle one. You were probably fine with the other 2
wilkingj
posted on 1/7/07 at 07:19 PM Reply With Quote
Weld a bit of Angle iron to the shelf. That'l fix it
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 1/7/07 at 07:45 PM Reply With Quote
I must weigh those things - a 10" 4-jaw chuck, a 12" faceplate, a 6" catch plate and a 24" c-spanner!
Whenever I want to put the 4-jaw on the lathe I always have to plan it carefully, as there is a high chance of putting my back out if I'm careless.
The solution will be a 1" thick piece of marine ply to go on top, with the shelf pulled up to it with screws. Probably find that the legs will collapse then...
DavidM
posted on 1/7/07 at 09:03 PM Reply With Quote
Won't the 1" marine ply be a bit heavy.
907
posted on 1/7/07 at 09:17 PM Reply With Quote
Shame on you David.
You can build a car, from scratch, a very nice one at that....
then you BUY a shelf unit.... in KIT form.
Paul G
stevebubs
posted on 1/7/07 at 09:23 PM Reply With Quote
Bit late, but Costco had some very robust looking shelving in the other day....
posted on 2/7/07 at 09:18 AM Reply With Quote
Originally posted by 907
Shame on you David.
iank
posted on 2/7/07 at 09:25 AM Reply With Quote
That's not machine mart's 'finest', that's their cheap and flimsy range
I got these ones (350kg per shelf allegedly) where the mdf shelves are supported on all 4 sides.
http://www.machinemart.co.uk/shop/product/details/cs5350-galv-quick-assembly-shelving/path/tool-racks-shelving-workshop-flooring
The hammer together assembly makes it a pain to move them, even when empty, though.
Anonymous
posted on 2/7/07 at 02:42 PM Reply With Quote
I've got a couple of those elsewhere in the garage - they're OK. I got given this one (that's my excuse anyway).
Screwed the plywood to the top of the bent shelf today - I've seen thicker metal on a baked bean tin...
