welshavon
posted on 15/8/07 at 03:26 PM |
Zetec plumbing
Getting to the final stages of plumbing in my Zetec and not sure on one off take. It's at the rear of the fuel rail / inlet manifold, it
currently has a 90 degree elbow fitted which is as it came with the donor engine. It looks like it could be a breather but not sure. Can anyone tell
me if this should be connected to anything and if so what. Hopefully theres a photo with the elbow circled.
Colin
welshavon
posted on 15/8/07 at 03:28 PM |
OK no photo, will try again.
Colin
posted on 15/8/07 at 03:41 PM |
Assuming the big circle it looks like the oil breather connector between the breather thingy on the block and the inlet manifold.
Ian D
posted on 15/8/07 at 06:22 PM |
It is the oil breather and connects into a metal pipe which straddles the back of the head. The far side plugs into the crank case breather box
beneath the exhaust pipes. I have posted the picture in my picture files for you to see. If you want more info send a U2U.
Ian
