Author: Subject: Drip tray
posted on 16/8/07 at 12:22 PM Reply With Quote
Drip tray
My car has a good old-fashioned x-flow engine, which has the regulation oil drips underneath.
I could make my own drip tray, but I'd much rather buy one if I can. There are some purpose-made ones available through the interwebbiethingy but, although they're quite cheap, the P&P is often huge.
I was just wondering if anyone has come up with a cheaper and readily-available alternative...
nib1980
posted on 16/8/07 at 12:25 PM Reply With Quote
cat litterr tray from wilkinsons, 32p
posted on 16/8/07 at 12:35 PM Reply With Quote
Good old Wilko's!
Any idea how big they are, roughly?
hobbsy
posted on 16/8/07 at 12:41 PM Reply With Quote
I used the end panel off a bath that I was about to throw away. About an inch deep all around and about 2 foot square approx.
posted on 16/8/07 at 12:42 PM Reply With Quote
Originally posted by David Jenkins
Good old Wilko's!
Just had a look at the Wilko site - the litter trays may be too deep. It's got to be 4" or less, total depth...
bob
posted on 16/8/07 at 12:49 PM Reply With Quote
I used a litho printing plate, nice and easy to fold the corners up worked a treat.
Pop along to a local printers David, plenty around they are worth a fair amount as scrap in large amounts but i'm sure on a saturday morning someone will oblige
posted on 16/8/07 at 12:51 PM Reply With Quote
I got a propagation try from a local garden centre. Just a bit bigger than A4 and 90mm deep.....
posted on 16/8/07 at 01:00 PM Reply With Quote
And you can get ones that are apporx A3 size (or whatever double A4 is!!!!).....
posted on 16/8/07 at 01:05 PM Reply With Quote
Roasting tray from an old cooker, I use it for services on my bike as well
posted on 16/8/07 at 06:32 PM Reply With Quote
But don't tell the missus eh Eeeh ek love - that Pork's smellin funny and just look at'smoke!!!
caber
posted on 16/8/07 at 08:08 PM Reply With Quote
I just use cat litter under the car and sweep it up when i take the car out! A lot less smelly than a real cat!
Caber
locoboy
posted on 17/8/07 at 06:29 AM Reply With Quote
I have cut round a plastic 45 gallon drum about 2 inches from the bottom.
Slides inder no problem and holds a surprising amount when dropping the oil.
Locoboy
posted on 17/8/07 at 09:14 AM Reply With Quote
Yes but our Chicken Castrolaise is to die for
DarrenW
posted on 17/8/07 at 09:54 AM Reply With Quote
i use bit of old carpet for my over zealous plumbed in central lube anti rust system.
thomas4age
posted on 17/8/07 at 10:19 AM Reply With Quote
just cut an old 5 liter oil flask in 2 halfs lengthways leave the plug on, and use the part that has the plug on as the cat-cher makes for easy pouring into something else also.
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
locoboy
posted on 17/8/07 at 10:58 AM Reply With Quote
Think we are moving off topic here a bit, DJ was after a DRIP tray, not something for draining oil into.
Mine does both, but i have a BEC so they dont drip oil
Or have i just cursed myself now!
Locoboy
thomas4age
posted on 18/8/07 at 05:46 AM Reply With Quote
You could use that as a drip tray, I did when I had the xflow in.... makes for easy disposal of the "dripage" (never knew what was comming out of that engine)
now I have the 4age the drip tray, only gets used for oilchanges,
grtz Thomas
