posted on 11/9/07 at 11:33 AM |
dremel sanding cylinders - cheap?
I have used up all my drem sanding cylinders, alson called drums, and am looking for a cheap source
these things: (top row really)
searching the bay of e but not found really cheap ones, quantity say 20 to 50 max.
Ivan
posted on 11/9/07 at 01:59 PM |
I don't know if the same applies where you are but in South Africa the cheapest source by far of abrasive products like this are normally the
specialist industrial abrasive supply companies - check out your yellow pages.
They are normally half the price of the large factors and twice the quality.
MkIndy7
posted on 11/9/07 at 04:03 PM |
The last place we found any cheep was a Model Air show.
Maybe try an Auto Jumble, model shop or somewhere that would sell them in bulk or a trade place and metioned
posted on 11/9/07 at 04:16 PM |
<begin rant>
This is a sore point for me - the astonishing cost of Dremel tooling. Considering that the US Dollar has fallen in value when compared to the Pound,
the Dremel accessories have gone UP in price over the same period.
One thing in particular amazes me - the cost of the large reinforced cut-off discs. IN B&Q (that well-known rip-off emprium) charge up to £15 for
10 discs - I can get Norton discs for my angle grinder cheaper than that! And they last no time at all.
Their other accessories are also overpriced, for what they are.
</end rant>
Now back to the topic...
iank
posted on 11/9/07 at 04:57 PM |
£1.69 for 6 of the 13mm ones?
http://www.tool-shop.co.uk/acatalog/Sanding.html
Their cut-off disks aren't much cheaper than B&Q. Maybe it's the UK distributor loading the prices?
Proxxon ones are even more expensive
http://www.tool-shop.co.uk/acatalog/Proxxon_Sanding.html
Anonymous
takumi
posted on 11/9/07 at 06:48 PM |
Yep, same problem.. I end up using a fair few when finishing off a port job. Mostly I try to use a burr for aslong as possible before using the
sanding drums to finish to surface..
I want a big bag of them...
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
theconrodkid
posted on 11/9/07 at 07:45 PM |
http://www.lidl.co.uk/uk/home.nsf/pages/c.o.20070917.p.Hobby_Tool_Accessory_Set_100_Pieces.ar2
any good?
who cares who wins
pass the pork pies
Avoneer
posted on 11/9/07 at 07:50 PM |
Get these for you normal drill:
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=19906&ts=40189
Awesome.
Pat...
posted on 11/9/07 at 09:25 PM |
Unfortunately with most tools I've found you get what you pay for.
Although Dremel cutting discs do seem rather expensive they last so much longer than the cheaper ones I've tried. I had a cheap cut-off tool
with equally cheap cut-off discs and not only did they look like a catherine wheel firework, they last about as long as well!! It's Dremel
originals for me everytime.... and I'm a tight git...
