Author: Subject: Yorkshire elbow on a fuel line ?
Macbeast
posted on 17/9/07 at 05:45 PM Reply With Quote
I thought something similar came up recently but damned if I can find it.
I'm using 8mm microbore for the fuel line and I want to take it through a right angle bend where it reaches the engine compartment. I can't get the bend sharp enough without it flattening the tube.
As far as I remember it was agreed that petrol would not affect solder. Would it be ok to use a Yorkshire elbow or would SVA say "not what a car manufacturer would use" ?
indykid
posted on 17/9/07 at 05:49 PM Reply With Quote
i used 3 to get the pipe from the tank to the filter. nothing was said at sva and nothing leaks after a year.
hth
tom
mistergrumpy
posted on 17/9/07 at 06:11 PM Reply With Quote
A ha great! Just solved my problem that I was going to ask too! Cheers
nitram38
posted on 18/9/07 at 04:57 AM Reply With Quote
Why not use a compression elbow?
It will make life easier if you have any fuel blockages etc.
indykid
posted on 18/9/07 at 10:50 AM Reply With Quote
valid point i suppose, but what would you have in your tank that would block 8mm pipe?!?
compression fittings were significantly more expensive in the shop i was in too
tom
PeterW
posted on 18/9/07 at 12:17 PM Reply With Quote
OK....
DO NOT USE A SOLDER FITTING...!!
Sorry for shouting, but there is a logical reason... If for some reason it leaks, the only way of stopping it leaking, or removing it, is by using a blowtorch... And blowtorches and petrol do not mix....
Use a compression, which will only cost a couple of quid from B&Q and it will be easier to remove etc in the future...!
I know someone who used a solder fitting and he 'scared' himself fixing it...
Pete
posted on 18/9/07 at 01:44 PM Reply With Quote
Originally posted by PeterW
OK....
Pete
what sort of psychopath tries to solder a fuel line after its been used!!!!!!!
Just solder it right first time
DarrenW
posted on 18/9/07 at 01:52 PM Reply With Quote
OK....
Pete
Im with Joel here. Should be able to test the joints by bunging one end (compression stop end?) and airline on other. Wont need high pressure. Soapy liquid should show up any leaks if you arent confident to solder. However observing cleanliness rules, good flux, decent torch and a bit extra solder should see it very well sealed first time. i just wait for the solder ring to appear out of the joint, remove heat and melt a bit extra solder into it.
