Author: Subject: Sticking expanded polystyrene to metal
chrsgrain
posted on 9/11/07 at 12:30 PM Reply With Quote
Hi all...
Its getting colder, and having lined the garage, I now need to insulate the metal double door. I've got some expanded polystyrene - and tried to stick it to the door with impact adhesive - but it melted the polystyrene (Doh!)
Any idea what would be good to use?
Chris
[Edited on 9/11/07 by chrsgrain]
Volvorsport
posted on 9/11/07 at 12:38 PM Reply With Quote
polyurethane adhesive .
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 9/11/07 at 12:47 PM Reply With Quote
Solvent free impact adhesive works reasonably well on a large surface area....
posted on 9/11/07 at 12:48 PM Reply With Quote
Otherwise some nice epoxy would do it (rather overkill though!!)
You could even use industrial (carpet adhesive) double sided sticky tape from B+Q.
twybrow
posted on 9/11/07 at 01:11 PM Reply With Quote
3M photo mount.
emsfactory
posted on 9/11/07 at 01:14 PM Reply With Quote
something that doesn't have styrene in it.
wilkingj
posted on 9/11/07 at 01:23 PM Reply With Quote
Safety Related
Just as an aside....
Keep your PVC cables especially power ones away and out of contact with polystyrene.
It leaches the oils from the PVC and it then the PVC crumbles thus making a safety hazard by exposing the wires.
Not a problem if its only short term exposure, but if it was permanantly touching, it would be a problem waiting to happen in the future.
Just a thought..
Best Regards
Geoff
http://www.v8viento.co.uk
andyharding
posted on 9/11/07 at 01:28 PM Reply With Quote
Expanding foam worked for us
jabbahutt
posted on 9/11/07 at 01:43 PM Reply With Quote
don't use no more nails!! I'd been better off nailing it.
Most of it is now held on with gaffer tape though I bet it won't be long before I open the garage door to find all the polstyrene all over the car and floor
chrsgrain
posted on 9/11/07 at 02:27 PM Reply With Quote
Thanks guys... I think I'll try the solvent free impact / spray mount.
I'll also check that non of the wires are imbedded in the polystyrene - most of them are surface mounted so should be OK
Chris
MikeR
posted on 9/11/07 at 04:11 PM Reply With Quote
i bought bubble wrap from ebay and stuck that to my garage door! Real locost
wilkingj
posted on 9/11/07 at 06:10 PM Reply With Quote
Chris
You can always cover the cables with gaffer tape etc.
Best Regards
Geoff
Macbeast
posted on 9/11/07 at 08:01 PM Reply With Quote
polystyrene tile cement ? As used for sticking polystyrene ceiling tiles to walls / ceilings
