Author: Subject: Throttle Body Flanges - Can anyone make these for me?
saigonij
posted on 18/11/07 at 08:39 PM Reply With Quote
I have made diagrams of the throttle body flanges i need to make. They look the same, but one is a mirror of the other - one has to go on the end of the manifold, and the other goes on the throttle body - with some silicon pipe in between. This is because there is not really enough height for the throttle body and a 90deg pipe in its original position, so im looking to relocate the throttle body...
Here is a link to the two images...
Would be good if they could be made of ali...
http://www.locostbuilders.co.uk/upload/manifoldEnd.jpg
http://www.locostbuilders.co.uk/upload/throttleBodyEnd.jpg
The pictures are big, so ill not post them directly on here...
Its basically a metal plate, with a 60mm hole in it. then over the hole, is a 60mm tube of about 30mm high...
Can anyone else me?
