Author: Subject: Circlip Removal?
Atomfun
posted on 2/12/07 at 06:30 PM Reply With Quote
Circlip Removal?
I need to change the wheel bearings on my Atom sometime soon.
As is commonly the case, the bearing is held in situ by an inner and outter circlip. The circlips on the Atom don't have any 'eyes' to help in their removal!
So my question. What is the best way to remove these circlips? Is there any technique?
John Cooper
'Ariel makes your whites browner'
oadamo
posted on 2/12/07 at 06:34 PM Reply With Quote
screw driver and hammer then refit one with the holes in. thats what i did anyway lol.
adam
Atomfun
posted on 2/12/07 at 06:43 PM Reply With Quote
That's the way I would normally do it too, but, the hub on the Atom is 'priceless' and I would need to be so careful not to damage it.
John Cooper
posted on 2/12/07 at 06:49 PM Reply With Quote
Can you use a small pick or screwdriver to get inside the circlip?
posted on 2/12/07 at 06:52 PM Reply With Quote
You need 3 hands.
A thin electrical screwdriver and something to stop the circlip from spinning in the groove. Push the screwdriver under the end of the clip and twist it so it lifts it out then work it round.
jono_misfit
posted on 3/12/07 at 11:33 AM Reply With Quote
sounds like a snap ring.
use one scre driver as a "stop" on one side then insert another in at 45 deg to channel bottom and slide in.
It should lift out of the groove and you can slide the screw driver round flicking it out.
Usually take a while to build up a technique.
