Author: Subject: Broken my Rivnut tool
saigonij
posted on 24/12/07 at 08:59 AM Reply With Quote
i cross threaded a rivnut yesterday, and then the bloody tool snapped when trying to insert a new one!
anyone tell me a few places that sell a replacement?
wilkingj
posted on 24/12/07 at 09:07 AM Reply With Quote
Use a Nut, a bolt, and a couple of washers, and you can fit the rivnut.
However, if you have a lot to fit, then the tool is the best item.
Shop around as the prices vary wildly on these tools. I have seen them for as little as a tenner, and up to £45 for the same item.
Best Regards
Geoff
http://www.v8viento.co.uk
Mr Whippy
posted on 24/12/07 at 09:45 AM Reply With Quote
the tool that came with my mk kit snapped on fitting the very first one, great
balidey
posted on 24/12/07 at 09:47 AM Reply With Quote
I too have broken one, luckily it wasn't mine
stuart_g
posted on 24/12/07 at 09:49 AM Reply With Quote
I've just bought one from here http://www.zygology.com/products/tools.asp?category=threaded%20inserts
i got a 7486-9612 boxed kit for £43.00 +vat. I've used it a couple of times and no problem so far, quick delivery too.
worX
posted on 24/12/07 at 10:04 AM Reply With Quote
£22 - ebay.
Used a few times and fine so far, although it doesn't feel as good as the Sealey one I borrowed a few times before buying one of my own, and because it doesn't feel as hardy, I've been quite careful with it...
John Bonnett
posted on 24/12/07 at 10:29 AM Reply With Quote
It should be possible to replace the threaded mandrel yourself. I stripped the thread off the M4 mandrel but replaced it with an M4 stainless steel stud locked in place. It has worked well ever since.
John
DaveFJ
posted on 24/12/07 at 10:36 AM Reply With Quote
If you can, buy one of these...
http://www.locostbuilders.co.uk/viewthread.php?action=attachment&tid=19808&pid=159285
They do rivets as well and are very well made.
Best £50 I spent on this build!.... (I bought mine at a show)
prices vary from £45 - £70 so shop around..
Check out this thread...http://www.locostbuilders.co.uk/viewthread.php?tid=23139
[Edited on 24/12/07 by DaveFJ]
Dave
Macbeast
posted on 24/12/07 at 11:33 AM Reply With Quote
Carbuilders Solutions I think
saigonij
posted on 24/12/07 at 12:18 PM Reply With Quote
just brought one from car Builder solutions..
thanks for the help guys.
NS Dev
posted on 24/12/07 at 12:55 PM Reply With Quote
the cheap (sub £40) ones last about five minutes.
If you want a cheap but robust one there is only one answer and its on this site.......
Danozeman
posted on 24/12/07 at 02:29 PM Reply With Quote
Iv got one like daves. Rivets and rivnuts. Excellent tool. Be careful with ali nuts though. Theyr easily stripped with the leverage.
Dan
Schrodinger
posted on 25/12/07 at 09:13 PM Reply With Quote
I have a Laser rivnut tool and I managed to break one of the mandrels. I contacted Laser and they sent me a replacement foc.
Keith
Aviemore
NS Dev
posted on 28/12/07 at 01:03 PM Reply With Quote
I had a laser one and broke the 6mm mandrel, plus the hinge pin and also the handle..........
