24vseven
| posted on 28/12/07 at 07:16 PM |
compressor help
hi folks i need a new pulley for my compressor i know machine mart sell them
but there listed as pcd measurements
mine measures 225mm diameter
what pcd do i need
thanks
Mark G
| posted on 28/12/07 at 07:30 PM |
PCD relates to the distance between the mounting bolts for the pully wheel.
Click the link below and you should be able to work it out.
http://www.needforspeed.co.uk/htmlpages/TechWheels.htm
[Edited on 28/12/07 by Mark G]
24vseven
| posted on 28/12/07 at 08:02 PM |
yea i understand pcd in that respect but for the pulley it fits onto a shaft
so i cant see how pcd is relevent
and theres no way to work a diameter out
http://www.machinemart.co.uk/shop/range/guid/38ED3488-DAAD-4081-A62A-16554351AF21
if this helps show what i mean
| posted on 28/12/07 at 10:06 PM |
You need to check the shaft diameter and match the bore size to it. As for the P.C.D. suspect that may be the diameter possibly measured from the
bottom of the vee?
Paul TigerB6
| posted on 29/12/07 at 07:22 AM |
The pulleys look like they are from the motor. At the size you are talking about then i guess you are after one for the air pump??
Is it a Clarke compressor then?? If so then possibly best to ring Clarke spares for a part number or ask Machine Mart themselves giving them the model
number of your compressor
indykid
| posted on 29/12/07 at 07:26 AM |
does this help at all?
notes on pulleys and belts
tom
NS Dev
| posted on 29/12/07 at 09:50 AM |
PCD when referring to a belt drive is the mean grip diameter.
There are a million ways to describe it but it is basically the bit of the pulley that has the same SURFACE SPEED as the belt thats touching it. its
usually something like 2/3 of the groove depth in the pulley.
For your compressor, just choose the pcd that is a bit less than your outer diameter. (prob about 10mm less at a guess)
r1_pete
| posted on 29/12/07 at 10:42 AM |
Is this any good to you, 225mm outside dia, 19mm shaft, A section belt.
r1_pete
| posted on 29/12/07 at 10:44 AM |
better attach the file....
24vseven
| posted on 29/12/07 at 05:25 PM |
it would have been but i bought one this morning just like that from hebdon bridge
owt to do with your good self?
thanks anyway
r1_pete
| posted on 30/12/07 at 01:47 PM |
No NTDWM, this is one I aquired for a lathe, now surplus....
As long as you're sorted...
Rgds.
Pete.
