locoR1
| posted on 6/1/08 at 07:22 PM |
Opinions on bending CDS tube
I've got a length of 2mm wall and 38mm o/d cds tube i need to put two 30deg bends in.
What are my options?
For those that have experience in bending cds. with it being a relatively small angle will i be able to bend it with a hydraulic bender? I
don't want to hire or buy one and it not do the job.
Cheers Dave....
Check out my CB500T Cafe Racer build diary
Paul TigerB6
| posted on 6/1/08 at 07:27 PM |
Would it not be simpler / cheaper to ask a local engineering / fabrication firm to do it rather than buy or hire the tools??
nitram38
| posted on 6/1/08 at 07:37 PM |
Normal hydraulic benders will crease the tube.
You need to have this done by someone with a decent set up.
Ask Martin Kennan of MK engineering.
I've had tubes rolled for the MotaLeira, but they sand filled them and welded caps on each end before rolling them.
big_wasa
| posted on 6/1/08 at 08:08 PM |
I want some bends doing in some 38mm tube for an atv buggy.
I was going to see if Grant @ Obp wants the bussines as he is only at Ramsey.
If you come up with a solution let us know
locoR1
| posted on 6/1/08 at 08:11 PM |
Grant was plan B
big_wasa
| posted on 6/1/08 at 08:30 PM |
NS Dev
| posted on 9/1/08 at 02:01 PM |
See below, it can be done, this was 45mm x 2.5mm CDS
12 tonne hydraulic bender with 45mm TUBE die. (NOT nom. bore pipe die)
  tube bender
annealing tube first:
  tube anneal
  main hoop
  main hoop 2
[img][/img]
locoR1
| posted on 9/1/08 at 09:46 PM |
Well plan B went T**s up Grant @ Obp can only bend 45mm tube
Now on to plan C only trouble is ive not got one yet
Going to try and find someone local to bend it or see if i can track down an old mate that should have a pipe bender then try Dev's method!
Cheers Dave...
NS Dev
| posted on 10/1/08 at 12:24 PM |
If you can find a 38mm bending die I can do the bends for you!
