Author: Subject: Rivnut tool... how to use?
thepest
posted on 23/1/08 at 06:55 PM Reply With Quote
I just bought myself a rivnut tool but it has no instructions. I have been trying a few blanks on some scrap. My question is: How far should you pull? Its not like a pop rivet where you break the end off so how would you know how far to pull the thread till it secures in place?
turbodisplay
posted on 23/1/08 at 07:00 PM Reply With Quote
There is normally a screw to prevent pulling too far, you set it once you have got it right.
I go by force, it is quite hard to damage steel rivnuts, ali it is quite possible.
Darren
Mr Whippy
posted on 23/1/08 at 07:11 PM Reply With Quote
certainly with the ones I've tried the tool 'automatically' snaps in half with a loud bang preventing the rivnut becoming too tight, which is fine if you have only one to fit
IDONTBELEIVEIT
posted on 23/1/08 at 07:23 PM Reply With Quote
hi, screw the rivnut onto the thread until the end is flush,insert in hole(fnah,fnah)squeeze handles initially they will be quite easy and then you meet more resistance this is the time to stop,slow and steady wins the race wayno!!! Rescued attachment bikepics-215271-320.jpg
thepest
posted on 23/1/08 at 07:41 PM Reply With Quote
ok thanks, So there is no setting to use depending on the thickness of the material you are riviting in?
Mr Whippy
posted on 23/1/08 at 08:13 PM Reply With Quote
no not really, you can tell when they go tight, the thing is when you bolt the final fitting on, say a skuttle, the rivnut just tightens up even more so it should never go slack, fool proof.
Macbeast
posted on 23/1/08 at 08:20 PM Reply With Quote
When the tool strips the thread in the Rivnut, that's just too much force
Seriously, if you take it easy, you can feel the Rivnut deforming and then it gets tighter. That's the moment to stop.
mad-butcher
posted on 23/1/08 at 08:22 PM Reply With Quote
Just one point about rivnuts make sure you buy the serrated ones, as they fold the serrations grip the metal preventing them from spinning, the plain shank ones tend to spin
Tony
tomblyth
posted on 23/1/08 at 10:27 PM Reply With Quote
just my opinion but i think riv nuts are poo I always weld a nut into the rails!
posted on 25/1/08 at 02:07 PM Reply With Quote
I totally disagree. It depends on what you are using them to hold.
... but back to the question. You need to work outthe preset on some similar thickness scrap and you can see when the flange has formed.
I was too lazy to do that and after stripping an aluminium one, I put on a steel nut onto the tool behind the rivnut (making fixing on sctuttle to hold a dashboard) whcih ofcourse won't be possible if you are doing it blind.
In that case it is getting the feel or presetting the tool.
