joneh
| posted on 23/2/08 at 10:37 PM |
Porn
Does anyone know how to remove vinyl stickers off a van? I've tried peeling them but they're stuck like....
ch1ll1
| posted on 23/2/08 at 10:39 PM |
we use a paint stripping gun to remove our stickers, or you could try a hair dryer
[Edited on 23/2/08 by ch1ll1]
joneh
| posted on 23/2/08 at 10:40 PM |
Hadn't thought of a hairdryer - cheers will give it a bash. Do you get them wet first?
graememk
| posted on 23/2/08 at 10:41 PM |
hairdryer and old credit card
Alfa145
| posted on 23/2/08 at 10:42 PM |
Just heat and a credit card/cd to peal them back worked for me
SeaBass
| posted on 23/2/08 at 10:44 PM |
Then some gunwash to remove the residue + Farecla G3 to cut out the fade round the letters so punters can't tell what the van used to be....
joneh
| posted on 23/2/08 at 10:47 PM |
Top tips guys - thanks will have a bash on Monday.
Jon
blakep82
er, where's the porn?
________________________
joneh
| posted on 23/2/08 at 10:48 PM |
Look at my avatar for a few minutes....
Christmas is gone now - i'll hunt for an easter girl.
onzarob
where is the porn!!!
I would use a hairdryer first at a heat gun can be a little fierce. but generally as above
joneh
| posted on 23/2/08 at 10:52 PM |
Much better
blakep82
| posted on 23/2/08 at 11:00 PM |
oooh, good morin'
guy over the road bought a cheap 2nd van because the guy who works with him was using his own car to put strimmers and other gardening stuff in.
we tried getting the stickers off and ended up using a blow torch. didn't burn the paint, er, too much. no, it didn't really at all, just
1 or 2 patches where i left it in place too long
mookaloid
| posted on 23/2/08 at 11:57 PM |
I find a jet washer is quite effective
skydivepaul
| posted on 24/2/08 at 08:29 AM |
all the above advice is good.
I took all the stickers off my race car last year with
hair dryer to get them nice and warm
plastic ruler to get them started
WD40 to get rid of the adhesive that is left on the car
took 3 nights to get them all off though!!!
best of luck
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
iank
| posted on 24/2/08 at 09:00 AM |
You can also use isopropyl alcohol to get the old adhesive off.
Anonymous
gazza285
| posted on 24/2/08 at 09:56 AM |
Steam wallpaper stripper.
thunderace
| posted on 24/2/08 at 10:02 AM |
in the body shop i worked it we used a kettle of hot water its the easyest way and no damage to the van.
RazMan
| posted on 24/2/08 at 10:39 AM |
I used to be a signmaker and have done a few hundred vans in my time.
Depending on the age of the decals (they get brittle with age) first try a jetwash at highest pressure. Once the water starts to penetrate it will
often lift off without leaving any residue.
Next try the hairdryer (definitely not a blowtorch! ) and soften the vinyl and gently peel back with your fingernails.
Remove any ahesive left behind with white spirit, followed by panel wipe or meths .
Finally T-cut the 'shadow' left behind if possible.
Raz
Delinquent
| posted on 24/2/08 at 10:56 AM |
We used to pour very hot water on before the jet wash, to soften the edges and give it a better chance to lift, otherwise same as.
DarrenW
| posted on 26/2/08 at 10:06 AM |
....followed by some G10 to bring the shine back.
DarrenW
| posted on 26/2/08 at 10:07 AM |
would a DA sander and 60 grit remove them quite quickly?
(a joke by the way - dont try that at home )
| posted on 26/2/08 at 10:45 AM |
WD40 is excellent for removing sticky stuff. If you ever try to remove a paper sticker and just the top surface comes off, a squirt of WD40 and leave
it for a minute or so and the rest will fall off.
