Author: Subject: How to remove silicone sealant
Humbug
posted on 28/2/08 at 08:50 AM Reply With Quote
Purely hypothetically if you had, say, put on a lexan screen and put a strip of silicone sealant along the bottom, and were now wanting to put an aeroscreen on, how would you get rid of the silicone sealant from teh scuttle?
I've tried a knife (removes the top part), meths and a heat gun. Any other suggestions?
Mr Whippy
posted on 28/2/08 at 08:59 AM Reply With Quote
good luck
jabs
posted on 28/2/08 at 09:01 AM Reply With Quote
Silicone remover, b&q sell it. don't know how good it is or how it would effect the paint/fibreglass
posted on 28/2/08 at 09:05 AM Reply With Quote
If it's the normal domestic type of silicon sealant (not a 'special' car type) then you can get silicon sealant remover from the plumbing section of most DIY stores. It's used when people want to replace sealant round a bath.
Probably worth trying it out on a remote corner of the GRP before using in a visible area! It does get used with baths made of fibreglass, so it should be ok.
HTH,
posted on 28/2/08 at 09:09 AM Reply With Quote
as they say, silicone removere, also removes paint,
r1_pete
posted on 28/2/08 at 09:17 AM Reply With Quote
Screwfix silicone remover
Humbug
posted on 28/2/08 at 09:20 AM Reply With Quote
ta for the tips
Mr Whippy
posted on 28/2/08 at 09:23 AM Reply With Quote
never used it before but reading the COSH sheet it does sound like a test should be done bofore hand
TGR-ECOSSE
posted on 28/2/08 at 09:34 AM Reply With Quote
I have used silicone remover on grp before and it made a realy good job but i would do a test patch first.
dhutch
posted on 28/2/08 at 10:25 AM Reply With Quote
Never used the stuff. But silcon is pretty inert stuff!
- A lot of modern baths/showertrays are grp so i presume it would be ok with them, or would mention specifcaly that is was not. However a test is alwyas bast. Have a good wipe of an area you can affor to loose, leave it a while, and see what it looks like!
I'd mechanicaly remove as much as i could first as well, a lot might just peel off depending on how well it stuck.
Daniel
Paul TigerB6
posted on 28/2/08 at 10:31 AM Reply With Quote
I used this to remove all the bathroom sealant from my part built Tiger B6. What a ball ache to do!!! It more hardened the sealant so it could be scraped off rather than simply removed it.
oldtimer
posted on 29/2/08 at 05:39 PM Reply With Quote
silicone remover
I've heard that washing up liquid is good at removing unset silicone sealant, never tried it though!..........
