Baldrick
posted on 10/3/08 at 01:17 PM |
Stripped Drain Plug Thread
The Gearbox drain plug hole on my old motorbike has stripped threads. The gearbox is Ally and the plug is steel. I need to repair and I guess there
are a number of options.
1. Run new ally weld onto the old hole and then recut threads.
2. Recut the thread larger and get a larger plug
3. Helicoil insert down to original thread size.
Which do you think is the best/easiest solution. Is it true that a helicoil would not be suitable because oil would still leak? I've used them
before but not in this sort of application.
Thanks,
RazMan
posted on 10/3/08 at 01:19 PM |
The easiest option would be to redrill and tap to a larger size imo, but that depends on whether you have sufficient metal to take the larger thread.
Raz
speedyxjs
posted on 10/3/08 at 01:20 PM |
I have no idea what helicoil is but i would think recutting a larger thread and getting a larger plug would be the easiest
MikeCapon
posted on 10/3/08 at 01:22 PM |
A helicoil should not provoke a leak as the sealing happens between the compressed face of the plug and the flat face surrounding the tapped hole. Is
there not a fibre/copper washer there?
www.shock-factory.co.uk
owelly
posted on 10/3/08 at 01:43 PM |
Or there is another alternative........
Use a tapered thread plug.
Whatever is the best size for your hole (!!) and as long as there is enough maet around the hole.
http://www.ppcmag.co.uk
r1_pete
posted on 10/3/08 at 01:45 PM |
I've repaired similar in the past using a BSPT (Tapered BSP) plug, after re-tapping of course. Minimises the risk of stripping again as there is
no shoulder to over tighten against.
bonzoronnie
posted on 10/3/08 at 02:56 PM |
Another vote for a re-tap
Ronnie
posted on 10/3/08 at 05:14 PM |
I would tap oversize --- try BSP tapered
Baldrick
posted on 11/3/08 at 08:03 PM |
Any idea where I would get a BSP tapered plug? Are they easy to get hold of? Current plug is 1/2" I think.
Thanks for all the input
907
posted on 11/3/08 at 08:22 PM |
I once owned a ZX10 that had a parallel thread drain plug with a copper washer.
The copper washer had worn to a sort of cone shape. When I tightened it the coned washer caused the ally sump to split.
I still hear that metallic ping in my dreams.
For this reason I would not advise a tapered plug in ally.
I would use a straight thread and a NEW copper washer.
Paul G
